B3 800 Gear Lever Pivot - MVAgusta.net
post #1 of 8 (permalink) Old 05-05-2016, 06:47 PM Thread Starter
2wheelsagain's Avatar
Running the tools over my B3 800 this morning and I found why my gear changes were becoming clunky and less consistent.
The gear lever pivot bolt was almost out and the lever had about 5mm play side to side and on an angle. Not sure what the torque spec is but its damn tight now.
Check your bolt on the bottom of the pic (blurry photo)
My Current Bikes
2014 VFR1200F ~ How Fast Do You Want To Tour?
2013 B3 800 ~ Naked Foolishness!
2wheelsagain is offline
post #2 of 8 (permalink) Old 05-07-2016, 03:50 AM
Put some locktite on there.
Lacsap is offline
post #3 of 8 (permalink) Old 05-07-2016, 06:43 AM
Djn
Djn's Avatar
Undignified end to maiden voyage..
That out-of-sight linkage nut fell off my then new (2014) F3675 as I rode home from the dealer. Had to crawl rest of way in 1st...
Loctite employed on its replacement and I now always carry a spare.
BTW this is my first post
DaveN.
Djn is offline
post #4 of 8 (permalink) Old 05-07-2016, 07:34 AM
Maximum Velocity's Avatar
Good one. Will check.
What a beast of a motorcycle!
Maximum Velocity is offline
post #5 of 8 (permalink) Old 05-07-2016, 08:15 AM
It's a nylock nut so shouldn't need loctite, but it won't hurt. I'd drill a hole though it and put a clip through it.
post #6 of 8 (permalink) Old 05-07-2016, 08:44 PM Thread Starter
On the B3 it's a hex bolt mate. No sign of any nylock nut.
Unless you're talking about the linkage
My Current Bikes
post #7 of 8 (permalink) Old 05-07-2016, 09:09 PM
Wink
Ah okay, picture is a bit fuzzy, so that is an Allen head bolt going through the rose joint turning into a thread on the other side, Loctite is about your only option, unless you can do some fancy drilling to get a safety wire through the bolt somewhere.
Or you can drill the bolt head and safety wire that.
post #8 of 8 (permalink) Old 05-08-2016, 03:13 AM Thread Starter
I'm talking about item #15 mate.
Think I'll keep a regular eye on it and see if it has a habit of winding out.
It may not have been torqued in PD.
My Current Bikes
