My F3 just failed - MVAgusta.net
post #1 of 15 (permalink) Old 03-11-2016, 05:39 AM Thread Starter
My F3 just failed
Hey guys I'm new to this site, i bought a 2014 f3 800cc back in december from a private seller. Everything was fine until 3/09/16 i was riding with friends and then noticed the front vibrating very odd. Then on the red light i held clutch all the way down in 1st gear and the bike was still tugging as if i were releasing the clutch to go. Then i turned it off then on rode it to where we were headed, adjusted the clutch lever to see if it was too close then it was okay for a bit but it was still feeling odd. I let the bike cool off for about 30 to 45 mins then went to meet some other friends then while riding as i reached about 20mph the bike just shut off in 1st gear and back wheel locked and slid. Controlled the slide then came to a stop and the bike now doesn't turn back on for anything and the bike was also stuck in gear. After a while i was able to get it into neutral and it still would not start. Please help. Do i need new clutch (plates, bleed the clutch line, etc.) Did my engine cease ?
Lumel187 is offline
post #2 of 15 (permalink) Old 03-11-2016, 10:03 AM
TrialsRider's Avatar
Only a guess on my part, if your clutch was the first thing to act up, I would think you should check the clutch itself and see if something came loose in there. Everything else you mentioned would be pure speculation.
… might be a problem if you aren't into working on your own machines.
Good luck and be sure to let us know the outcome.
TrialsRider is offline
post #3 of 15 (permalink) Old 03-11-2016, 04:50 PM Thread Starter
Mmmm I'm not a very good mechanic, this is actually my first bike lol pretty stupid i know but i dreamed of this bike always so i got it. I mean ummm how hard can it be ? open clutch cover check plates right? This is so not gona go well darn it.
Lumel187 is offline
post #4 of 15 (permalink) Old 03-11-2016, 04:59 PM
flyboyk's Avatar
No it`s not, your words "Mmmm I'm not a very good mechanic". You wouldn`t even know what to check with the clutch plates. Take it to the dealer.
2014 MV Agusta F4
Moto Guzzi 1100 Sporti
Yamaha R1
Honda CT90
flyboyk is offline
post #5 of 15 (permalink) Old 03-12-2016, 08:32 PM
You bought an 800cc F3 as your first ever motorcycle!
What were you thinking and who is the that sold it to you.
post #6 of 15 (permalink) Old 03-12-2016, 10:06 PM
Just take it back to the dealer mate, this is warranty work.
post #7 of 15 (permalink) Old 03-13-2016, 12:48 PM Thread Starter
What exactly is under warranty work because i think warranty is for a year only and it's a 2014 bike. And i started riding on a Yamaha r6 then i got the Mv
Lumel187 is offline
post #8 of 15 (permalink) Old 03-13-2016, 03:25 PM
Maximum Velocity's Avatar
Normally it's two years.
What a beast of a motorcycle!
Maximum Velocity is offline
post #9 of 15 (permalink) Old 03-13-2016, 06:51 PM
Lumel PM sent
sleiper1 is offline
post #10 of 15 (permalink) Old 03-13-2016, 07:47 PM
Ducati23's Avatar
Good advise. No one on a forum can diagnose the issues with your bike sight unseen. Have a good mechanic check it out. Could be any number of things. You'll be back in action in no time at all. Best of Luck!
D23
CCS/ASRA #19
'Yamaha R1 Superbike
MV F3RC
Zuma 125
Ducati23 is offline
