F4-1000S front suspension problem and question - MVAgusta.net
post #1 of 7 (permalink) Old 06-27-2007, 02:50 AM Thread Starter
mv2envy's Avatar
hey guys, i have a 2005 f4-1000s i weigh in at a wopping 200lbs, my front fork preload adjustment is set to the tightest, fully closed, turned all the way clockwise. and my bikes sag from the forks full extended to me siting on the bike in riding position is 37-38mm is this normal for this bike, or have my springs worn out and need replacing, or are these springs just too soft for my body weight? the bike has 16000miles on it. is this a warranty issue? im still under factory warranty.
mv2envy is offline
post #2 of 7 (permalink) Old 06-27-2007, 11:18 AM
Ball & Chain magnet
Djester's Avatar
the front sags?? or the back sags?? maybe you need to change to a heavier oil for the front shocks??
Djester is offline
post #3 of 7 (permalink) Old 06-27-2007, 11:34 AM
boussias's Avatar
if it's the front suspension then try adding some oil. Go in small measures. What I mean is first add 5ml and then calculate the sag. If still you have used all the preload then try adding some oil. If still that doesn't work try replacing the springs with ones that match your weight.
Kostas
boussias is offline
post #4 of 7 (permalink) Old 06-27-2007, 06:05 PM Thread Starter
mv2envy's Avatar
its the front suspension. but im going to have race tech revalve and respring my complete suspension. i just wanted to know if anyone els was experiancing this problem, thanx for the replys
mv2envy is offline
post #5 of 7 (permalink) Old 06-27-2007, 06:09 PM
Allan Gibbs's Avatar
Race Tech did a custom adjustment of my F41000S during a Pro Italia clinic. I'm 210 lbs and he still set the front preload to about 3 turns which is very soft since the manual's soft setting is 4 turns. Handles well but I've since go back to the manual's standard setting which works best for me.
Allan Gibbs is offline
post #6 of 7 (permalink) Old 06-27-2007, 06:16 PM Thread Starter
mv2envy's Avatar
hi allan, im going to have racetech revalve and respring my suspention, not adjust it, i can adjust my own suspension.
my problem is that i used the mv agsuat mannual to adjust my suspention using the standard settings for my bike, and my forks keps bottoming out, and the air ducts hit my newley painted front fender and put 2 large plastic deep nicks on it. thats when i noticed something was wrong and checked my sag.
front sag should be 35mm (about) from fully extended to rider on the bike in riding position.
mine is at 37-38mm right now, but the preload is all the way closed, no more room to tighten.
and im not sure what adding oil is going to do if its the springs that controll preload.
mv2envy is offline
post #7 of 7 (permalink) Old 06-27-2007, 07:21 PM Thread Starter
mv2envy's Avatar
i just got off the phone with Pat at pro italia, he confirmed that this is not normal, im just going to take the bike to him to look at as soon as i get done with installing my brembo brake and clutch masters, the bike is apart right now. i hate having down time. lol, i wana be on 2 wheels.
mv2envy is offline
