Need Help - F4 R Front Wheel Torgue Values - MVAgusta.net
post #1 of 4 (permalink) Old 06-22-2007, 04:23 PM Thread Starter
DYL-Jim's Avatar
This is my first time removing the front wheel on my F4 1000R and I can"t find torgue values for the following fastners:
Front Axle
Pinch bolts
Brembo Radial Calipers (do they need to be removed?)
Thanks for any help.
R/ DYL-Jim
1999 BMW K1200RS
1999 Kawasaki KLX300R
2007 MV Agusta F4 1000R
2012 Ducati Panigale 1199S Tri
2018 KTM 390 Duke
DYL-Jim is offline
post #2 of 4 (permalink) Old 06-22-2007, 05:22 PM
MV-999R's Avatar
Front Axle
Pinch bolts
All i have are the torque values for the tambo or the S, so no radial mounted caliper torque.
Front Axle on the Tambo is 60 to 65 NM
What to you mean with Pinch Bolts?
MV-999R is offline
post #3 of 4 (permalink) Old 06-22-2007, 06:02 PM Thread Starter
DYL-Jim's Avatar
Thanks MV-999R!
The pinch bolts are in the lower clamps that hold the front axle tight.
R/ Jim
R/ DYL-Jim
1999 BMW K1200RS
2018 KTM 390 Duke
DYL-Jim is offline
post #4 of 4 (permalink) Old 06-22-2007, 09:03 PM
lizzardo's Avatar
From my notes:
front brake caliper 44 N-m (32.5 lb-ft)
front axle clamps 22 N-m (16 lb-ft)
That's for the older calipers, but should be about the same if the bolts are the same size. I think the older ones are 8 x 1.25.
2008 MV Agusta F4 312 R
2002 Ducati ST4S
1998 Ducati 748
1994 Ducati 900SS
1980 Yamaha TZ250G
lizzardo is offline
