Engine hunting at idle - MVAgusta.net
post #1 of 8 (permalink) Old 06-01-2007, 07:41 AM Thread Starter
Unhappy Engine hunting at idle
F4 1000R, since the 600 mile service the engine hunts during the warming up period and on occasions whilst hot at idle, once off the idle it's OK any suggestions
Bob T is offline
post #2 of 8 (permalink) Old 06-01-2007, 08:15 AM
mikef4uk's Avatar
They tend do do this worse with open silencers and too rich an idle mixture, 4%co is too much for an R, they're better around 2.5%co
mikef4uk is offline
post #3 of 8 (permalink) Old 06-03-2007, 05:36 AM
agusta01's Avatar
Agree, mine did same, was running about 4.5 co, problem resolved when re set at 2.5
agusta01 is offline
post #4 of 8 (permalink) Old 06-03-2007, 09:54 AM
Mine idled decent at 4.5% CO but the bottom to mid felt a little on the lean side. I richened the mixture a little bit (idle trim from -13 to -9) and it feels a bit better in the bottom end there. I am guessing I am around 5% CO since I didn't recheck it. It hunts a bit when cold and seems to get better when warm but still occasionally hunts. ON-OFF throttle behavior is much better a little richer and the bike seems to make more power where it is at.
RobP is offline
post #5 of 8 (permalink) Old 06-03-2007, 04:00 PM
Robp what are using to record the measurements for the adjustments?
filatesta is offline
post #6 of 8 (permalink) Old 06-03-2007, 06:35 PM
mikef4uk's Avatar
Do you have Rg3's Rob?
Mine feels stronger at 4% co, but just hunts at idle, I suspect a dyno set up of my PC would sort it though
mikef4uk is offline
post #7 of 8 (permalink) Old 06-03-2007, 09:05 PM
I'm using the Gunston gastester. You have to sniff at the midpipe bung in order to get repeatable results.
RobP is offline
post #8 of 8 (permalink) Old 06-04-2007, 05:36 AM Thread Starter
Thanks everyone for your replys will get down to the agent and ask him to check the co
Bob T is offline
