Oxygen sensor - MVAgusta.net
post #1 of 8 (permalink) Old 05-19-2007, 11:48 AM Thread Starter
robr001's Avatar
Oxygen sensor
I'm about to change the headers on my 312R but not sure about reconnecting the oxygen sensor. Will the FI give an error when I disconnect the oxygen sensor?
Rgds,
Rob
robr001 is offline
post #2 of 8 (permalink) Old 05-19-2007, 04:50 PM
mikef4uk's Avatar
Rgds,
Rob
I take it your not going to reconnect it in the new headers?, most car ecu's will throw an engine ecu light up but normally default to a standard setting, I don't know what the MV will do
mikef4uk is offline
post #3 of 8 (permalink) Old 05-20-2007, 06:41 AM Thread Starter
robr001's Avatar
I'm in doubt about reconnecting. For about any other brand they sell oxygen sensor eliminators to prevent the FI system from running in safe mode
robr001 is offline
post #4 of 8 (permalink) Old 05-20-2007, 11:26 PM
minime's Avatar
Usually an oxygen sensor is required in a close loop EFI system. Removing the oxygen sensor usually puts the bike/car into limp home mode which usually means the timing is backed way off, fueling is on the safe side and revs are limited to very safe levels. This ensures that you can still ride/drive to the closest workshop to sort out.
I'm not sure on the MV as I don't have a 1000R or R312.
minime is offline
post #5 of 8 (permalink) Old 05-21-2007, 03:50 PM Thread Starter
robr001's Avatar
Normally that sensor operates only between 2000 and 4500 rpm but it does override PC settings so that's why I want to get rid of it.
robr001 is offline
post #6 of 8 (permalink) Old 05-21-2007, 04:02 PM
mikef4uk's Avatar
Car Lambda's tend to switch to open loop control on high rpm or throttle pos'ns, maybe you should talk to Technoresearch? www.technoresearch.com and ask them if their lead/programme alows you to turn the closed loop off or take the Lambda out of circuit, They do list a single make application for the 312R
mikef4uk is offline
post #7 of 8 (permalink) Old 05-22-2007, 04:27 PM Thread Starter
robr001's Avatar
Thanks Mike that's interesting info, will see what they can do
robr001 is offline
post #8 of 8 (permalink) Old 05-22-2007, 05:03 PM
JamesC's Avatar
Some people also find a certain resistor works to trick the computer into a base setting. Haven't heard that for MV's yet
JamesC
JamesC is offline
