Small leak here and there - Page 2 - MVAgusta.net
post #11 of 20 (permalink) Old 03-31-2014, 09:39 AM
You have a clutch pushrod seal gone bad.
post #12 of 20 (permalink) Old 03-31-2014, 11:23 AM
The bad news is that neither MV nor Ducati sell that seal separately, only as part of a whole replacement slave unit. Hopefully someone here can advise you where to get a compatible seal. (I've always found it rather disgraceful that you can't buy a perishable part like that one its own!)
If you replace the seal, make sure you clean the bore also. Otherwise a new seal won't last as long as it should.
Si
TheCatWhisperer is offline
post #13 of 20 (permalink) Old 03-31-2014, 04:15 PM Thread Starter
NICO312RR's Avatar
Keep it at min.
Will do! thanks!
NICO312RR is offline
post #14 of 20 (permalink) Old 03-31-2014, 04:16 PM Thread Starter
NICO312RR's Avatar
Right on!! will get that fixed in the winter. Thanks
post #15 of 20 (permalink) Old 03-31-2014, 04:16 PM Thread Starter
NICO312RR's Avatar
Si
IŽll try and look up the size of that seal! thanks!!
post #16 of 20 (permalink) Old 03-31-2014, 06:25 PM
Wink
clutch slave seal;
its a 1 3/16" automotive brake master cylinder seal
GM's and Toyotas
0.825 ID x 1.200" OD x 0.200" wide
try KTM and BMW only they sell Brembo internal parts
OK Aprilia sells the slave seal for $26 but thats it
before anybody thinks everything is metric, check most Honda front M/Cs its cast in "1/2" "
Mercedes transmission input shafts were from day 1 .....1 1/8" 10 spline, just like my Chevy
post #17 of 20 (permalink) Old 04-01-2014, 01:24 AM
MVAgusta.net Sponsor
mitchy's Avatar
Clutch slave cylinder kit.Hopefully they are still available.We were all told that the seal is correct for the original slave cylinder.
Originally Posted by MV1 View Post
Yeah sure I got you Donsy, here you go..
http://www.ebay.com/itm/190354695693...84.m1423.l2649
Bike- F4 1078 312rr
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is online now
post #18 of 20 (permalink) Old 04-04-2014, 08:18 AM Thread Starter
NICO312RR's Avatar
Great guys! IŽve got all I need!! Thanks everyone!!
post #19 of 20 (permalink) Old 06-13-2014, 02:45 AM
marcoma's Avatar
Nico - did you manage to cure the leaking oil? I think I may have the same issue....
06 MV Agusta F4 (first reg in 08 with 08 bodywork)
13 Suzuki V-Strom
06 Anniversary Yamaha R6
02 Honda RC51 SP2
06 Anniversary Yamaha R6 (yes, I have two!)
05 Yamaha WR450
marcoma is offline
post #20 of 20 (permalink) Old 06-16-2014, 10:59 AM Thread Starter
NICO312RR's Avatar
NO I HAVENT! Like DONSY said, my clutch pushrod seal gone bad and it looks like too much work for me. I will get it done within the next month or two. I dont get to ride it that often.. I only ride on sundays 20 or 30 milles and wipe the oil off every time I stop home.
My water pump also leaks a bit but since its not really a big leak I havent done anything either. ITS WINTER TIME OVER HERE!! By august/september I should have everything fixed.
The other issue I got is my speedometer.. but IŽll get there too!!
