Hello,
As you may know I've just bought an UK-spec MV F4S 750 that I'm going to bring back with me to Sweden. My question is:
As the dip beam headlight is assymetrical for driving on the lefthand side of the road, and in Sweden its r/h side, is there anyway to adjust that or maybe turn the dip beam upside-down to get the assymetrical bit right?
The guy I bought it from said it was the same dip beam on ALL MV F4 where ever they went in the world, and that it was adjustable, but I find this hard to believe. I haven't yet got around to strip the light, so if anyone know from the top of their heads, please let me know..
// Cris
Sponsored Links | |||
Advertisement |
You sure its off-centre?, I was riding in the dark 2 nights ago and I can't pick it.
They can be modified for r/h driving, however it is not as easy as "flicking a switch". You must make a modification inside the projector, will try and locate some photos...
Emoto: That would be very helpful, thanks alot!
// Cris
I also noticed that the beam also dosen't project out far enough so I just changed out to a brighter buld (PIAA) and it fixed both problems.
// Cris
Originally Posted by crille_h
What do you mean? Did the bulb it self make the dip beam more assymetrical?
aha i see...
// Cris
So does PIAA makes a direct replacement part (bulb) for the MV? or do you need to upgrade the system in someway for it to work, like the HID?
Sylvania also makes a very bright one too.
They are definately not as good as the HID kit, but alot better than the stock ones.
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
