what handlebar risers to use on my 05 f4 1000 ??? - MVAgusta.net
post #1 of 4 (permalink) Old 05-11-2007, 04:55 PM Thread Starter
superbike-italia's Avatar
hey guys, this is probably already been asked but....iwanted to put a set of risers on the f4, i have a set on the duc and it makes all the difference in the world. i called fbf today and they informed me that the set they have wont raise the position it would lower it. huh ??? im sure someone has put these on their bike , and how well are they on the mv??? thanks !
95 ducati 916[funeral]
06 brutale 910s-[sold]
05 f4 1000s[sold]
05 aprilia tuono factory R[best bike ever made !!!]
07 aprilia sxv 5.5 supermoto[sold]
FINE WINE,FINE FOOD, FINE WOMEN,FINE CARS AND FINE MOTORCYCLES.!!!
ITALY !!!!
superbike-italia is offline
post #2 of 4 (permalink) Old 05-11-2007, 05:32 PM
quickfixx's Avatar
Send a message via AIM to quickfixx
to my knowledge the fbf risers were designed for the f4750. the f4 1000 design was higher than the 750
quickfixx is offline
post #3 of 4 (permalink) Old 05-11-2007, 06:51 PM
Mogan's Avatar
CycleCat is a possibility. I got this email response from my inquiry...
We do have a riser system for the MV Agusta F4 series. I have it on my 750 and it helps quite a bit. The problem that Jenifer mentions is between our riser and the brake and clutch master cylinders. In order to use our system you need to change the masters to a radial type pump. I use the Brembo units on my bike and between adding these and also adding the Alth brake rotors that we sell, the braking of the bike was significantly improved. We do not advertise this as a kit due to the need for the additional products needed to make it work. Cycle Cat likes to include everything necessary to install our systems so this is inconsistent with our philosophy. The Brembo units will usually cost about seven hundred dollars and the Cycle Cat bar system is $290. If you are experiencing wrist pain or numbness as I was it still may be worth it for you. Our bars are designed to allow you to adjust them to fit you and your riding style. If you would like to discuss this further please feel free to call me at the number below.
Chris Calovini
Director of Business Development
Cycle Cat
ph: 614.577.8080 x 102
fax: 614.577.8088
email:[email protected]
'05 FJR 1300
'05 F4S "Custom"
'04 Brutale
'08 Suzuki DR650
'74 RD350 Restoration Project
Mogan is offline
post #4 of 4 (permalink) Old 05-12-2007, 08:05 AM
Someone sells the complete "kit" to make this work. Let me find the link here....
http://www.motowheels.com/italian/
Go to the pull-down menu at the top and choose Aluminum Billet for European bikes. It's on the first page, top right. Cyclecat risers with the Brembo controls.
Michel
RSV-R Factory
MVness is offline
