Page 1 of 2 | 1 | 2 |
so I picked up a 2000 F4 and the thing is a dog and gets about 75 miles to the tank?? It falls completly on its face up to 6000 rpm and is even hard to get going from a stop..The intake is loud as can be with barly any noise from the exhaust and blows some smoke alot of the time when reving hard... Tell me this, If I dumped the clutch in 1st gear going about20-30mph should the front end come up at all?? well it dosent. It feels like a damn 250.. WHAT THE HELL MV
Sponsored Links | |||
Advertisement |
Not sure about lifting the wheel cause I have a 1000, but I would extect it should.
I hope its not as bad as it sounds, get it checked out.
Silly Old Sod
Location: Now residing on the costa del Yorkshire, England
I'd get a competent mechanic to check it out asap, sounds like you've bought a bit of a pup.
Keep one wheel down!
No MV's in the garage anymore
but I pop in here from time to time. Come to think of it I don't have a garage since the old one burnt down!
I bought a 2000 F4 last year that was a little bit like that. It was down to the fact that the engine oil hadn't been changed in 6 years. (Though the bike was very low mileage so hadn't been serviced since it's 600 mile first service.)
I changed the oil and it ran a lot better, revved more willingly and ran a lot cooler.
Mine also smokes a bit when cold, but it's actually steam from moisture build up and from any water ingress into the exhaust if I've washed it.
My fuel economy is pretty bad, and I know I need to get it set up, but it sounds to me like yours is way too rich. There's probably not too much wrong with it, just sounds like it needs a decent service. Oh, but don't expect decent power under 6k rpm regardless. They really do have two-stroke like power curves.
Si
Si
can you lift the front wheel of the ground at all?? cat
Yep mine was like this, get a service or do one yourself I bet the plugs are knackered/well fouled! Change the oil and air filter then take it for a good ride and I reckon it should sort it.
The power on the 750 only really starts ay 6K so if you want to make progress you need to rev it!
'98 916 SPS. '01 MV F4S 750.07 Suzuki VStrom
I couldnt get the spark plug socket past the valve cover and the air filter was horrible also what oil can I go get?? It has only 4300 miles on her.. thanks for the help
bemmin540,
Seek immediate MV service help BY AN MV EXPERT.
Goodluck
Goodluck
Don't blame MV though, blame whoever you bought it from.
I use the Agip 4T when I can find it, but I've used motul in the past. Any motorcycle oil should be fine though.
I have an '00 750 also.
True: The intake is LOUD, the exhaust is not. It doesn't get screaming until past 6K.
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
