rear brake lever(need help) - MVAgusta.net
post #1 of 20 (permalink) Old 04-10-2007, 07:52 AM
anothermvfanatic
Guest
hi all
hpe u all are well
was wondering if anyone can give me some advice on what to do with my rear brake lever, slightly hitting or touching the fairing. Ever since i got a new right side fairing (original one), it touches. I took it to my mechanic the other day for a service, and he was going to install a spongey thing..... but i thought id pose the question.anyone got some tips.
Just to explain it a bit more. If i put the old one (fairing) on it doesnt touch.
post #2 of 20 (permalink) Old 04-10-2007, 09:39 AM
anothermvfanatic
Guest
anyone?
post #3 of 20 (permalink) Old 04-10-2007, 09:39 AM
anothermvfanatic
Guest
?anyone?
post #4 of 20 (permalink) Old 04-10-2007, 09:39 AM
anothermvfanatic
Guest
tough crowd
post #5 of 20 (permalink) Old 04-10-2007, 09:51 AM
Ball & Chain magnet
Djester's Avatar
what part hits? the front?? sounds like the paice is warped or wasn't a good mold
Djester is offline
post #6 of 20 (permalink) Old 04-10-2007, 10:13 AM
anothermvfanatic
Guest
see pic
post #7 of 20 (permalink) Old 04-10-2007, 10:14 AM
anothermvfanatic
Guest
the foot rest part hits the fairing when depressed, but iof it were to stick out bit ,more (ie with a foam insert) then ity doesnt hit
post #8 of 20 (permalink) Old 04-10-2007, 10:21 AM
Ball & Chain magnet
Djester's Avatar
i guess you dont want to adjust the lever up a bit huh? trying the foam might work....don't know if the heat will do anything to harm it though.....
Djester is offline
post #9 of 20 (permalink) Old 04-10-2007, 10:35 AM
anothermvfanatic
Guest
yes hdnt thought about the heat part, tried adjusting it, i think im at the limit though
post #10 of 20 (permalink) Old 04-10-2007, 10:43 AM
Ball & Chain magnet
Djester's Avatar
what if you took the lever completely off....turned it upward a bit...then re-attached it and then you could have some adjustability...... but a *flat foot* riding style is needed. have you got the bike hot a few times?? maybe this could help the plastic to adjust or kinda mold into the right position.... just a thought. as I have no idea if that would work.... is anything on the other side keeping it from going to the original position..?? ie hoses, tubes, ect...... if something was to be in the way on the left side, it would pull the right side inwards
Djester is offline
