312R injector problem. WonŽt start up - MVAgusta.net
post #1 of 82 (permalink) Old 09-16-2013, 07:59 AM Thread Starter
NICO312RR's Avatar
Hi everyone. I recently bought a 312RR and love it! well, loved it till it stoped running. I was riding along in town one day and passed over a speed bump at about 15mph and the bike shut itself off! Everything looks normal it just wonŽt turn on! everything else works fine. Took it appart and got good spark, fuell pump works, fuses are all fine, and I took off the air box and sprayed some fuell directly at the intake and it run for a couple of seconds so my guess is MY INJECTORS ARE NOT WORKING. Is there a relay that might had gone bad, a hidden fuse or maybe my ECU gone bad... has anyone run into this issue before? I would really appreciate any tip on this. Thanks!!
NICO312RR is offline
post #2 of 82 (permalink) Old 09-16-2013, 08:10 AM
spypyp's Avatar
Hi and welcome to the forum.
Did you try your injectors still plugged in but not in the throttle bodies. They should spray fuel if the bike cranks.
Did you try the fuses on the left hand side there is from memory a 40amp.
spypyp is offline
post #3 of 82 (permalink) Old 09-16-2013, 08:26 AM Thread Starter
NICO312RR's Avatar
Hi Spypyp, yes I allready replace both the 40amp fuses and also just in case all the 15AMP on the fuse box at the right hand side of the bike, both relays on the front and the one on top of the fuse box as well...
post #4 of 82 (permalink) Old 09-16-2013, 08:28 AM Thread Starter
NICO312RR's Avatar
there is a relay at the tail section, called a latch relay, haveŽnt replaced that one but I got good spark, itŽs the injectors that wonŽt spray
post #5 of 82 (permalink) Old 09-16-2013, 08:29 AM
spypyp's Avatar
Does the engine turn over when you try to start it? Or does it just have spark. And did you try the injectors out of the throttle bodies.
spypyp is offline
post #6 of 82 (permalink) Old 09-16-2013, 08:30 AM
spypyp's Avatar
Try the ecu, un plug it and then plug it back in something might of come loose
spypyp is offline
post #7 of 82 (permalink) Old 09-16-2013, 08:42 AM Thread Starter
NICO312RR's Avatar
the engine turns over and runs for a couple of seconds if I spray fuell directly on the intake but I haveŽnt taken the injectors off. But I can assure you they are not spraying. I already disconected the ecu a couple of times and double checked all the conectors since the problem started while passing a speed bump but everything looks ok. what do you know about the latch relay? still got that on my "to do" list
post #8 of 82 (permalink) Old 09-16-2013, 08:48 AM
spypyp's Avatar
Usually if your latch relay is faulty it will drop a fuse. Not always but these things being italian anything is possible. see if someone can lend you one instead of buying one for nothing.
Are you in the U.S
spypyp is offline
post #9 of 82 (permalink) Old 09-16-2013, 08:51 AM Thread Starter
NICO312RR's Avatar
I guess i could try that. allright IŽll get back to you once I try that
post #10 of 82 (permalink) Old 09-16-2013, 09:11 AM
spypyp's Avatar
Have you unplugged the relay and checked the contact pins. try this first and see what happens.
Good luck and let us know how you get on.
spypyp is offline
