2005 MV Agusta F4 1000 fueling problem/surges - MVAgusta.net
post #1 of 18 (permalink) Old 08-12-2013, 09:35 PM Thread Starter
I own a 2005 MV Agusta F4 1000$ with 20,000 miles. I've put 6000 of those miles on the bike. I've been diligent with the maintenance and have taken it to the dealer for basically everything. I had the major 15,000 mile service a few months after I bought it. I haven't done any crazy modifications. I've added the Muzzy fans and that's about it. Recently, the dealer replaced a fuel injector relay.
Anyway, my bike starts up no problem. It's when I start to ride that things get nightmarish. Idling at a light, she sounds like an old VW Bug that is about to cut out at any minute. Some times she dies, sometimes she doesn't. One thing for sure is that I have to feather the clutch and rev the engine to get her going. When I'm on the highway, if I open the throttle nothing happens for about 5 seconds and then I'll be hit with a surge. It doesn't matter what gear I'm in. Even with a steady throttle, the bike will surge. It feels as though it's getting a lot of fuel and then not enough. With this problem, turns become things to be avoided because I'm afraid a surge will kick in while I have her leaned over. I've tried fuel additives, changing gas stations, all to no avail. I live in a pretty humid and hot area. Lately, it's been 89 degree but with the humidity it feels like 95 degree. I really hope you guys can shed some light on the situation. I'm very frustrated and don't know if I can take it any more. I haven't had one trouble free ride yet. It's a pity, because she so beautiful to look at, but not to ride. Any ideas?
MVgofast is offline
post #2 of 18 (permalink) Old 08-13-2013, 08:28 AM
First...where are you?
Second...do you have decent mechanical skills?
Third...can you check the TPS setting?
post #3 of 18 (permalink) Old 08-13-2013, 10:06 AM Thread Starter
I'm in South Florida. I have decent skills. I've never checked the TPS sensor. The dealer checked it though.
MVgofast is offline
post #4 of 18 (permalink) Old 08-13-2013, 04:30 PM
Did this problem begin after the dealer replaced the fuel injector relay, or was it present before?
post #5 of 18 (permalink) Old 08-13-2013, 05:08 PM
Have you changed the EBS relay?
post #6 of 18 (permalink) Old 08-13-2013, 09:48 PM Thread Starter
I checked my records to be sure. They changed the EBS relay in June. It seemed to perform better for a few weeks. Three weeks ago, I had the gaskets around the gearshift, and clutch replaced because it was leaking a lot of oil. Since then it has been worse.
MVgofast is offline
post #7 of 18 (permalink) Old 08-13-2013, 10:53 PM
You have a 16M ECU that requires very specific throttle body synch, TPS adjustment and idle CO% trim.
Did your dealer replace the plugs? with what kind? Can the tell you where the TPS is and what they set the CO % to?
The MV with 16M ECU is very sensitive to proper tune. I suspect that is all you are dealing with. Or perhaps a fuel filter that is in need pf replacement....that could be it as well.
post #8 of 18 (permalink) Old 08-13-2013, 11:50 PM Thread Starter
I'm going to stop by the dealer tomorrow and see what they say. I'll let you guys know!
MVgofast is offline
post #9 of 18 (permalink) Old 08-14-2013, 04:55 AM
Interesting, Ed, as I was thinking fuel filter, too.
post #10 of 18 (permalink) Old 08-14-2013, 01:53 PM Thread Starter
I changed the filter recently. The dealer suspects it may be a coil. We'll see. I hope it's something easy like a clogged filter...
MVgofast is offline
