Electrical issue please HELP! - MVAgusta.net
post #1 of 14 (permalink) Old 03-25-2013, 12:49 AM Thread Starter
Question Electrical issue please HELP!
So after pulling my 2007 f4 out of storage, I noticed I forgot to remove the battery. Naturally it was dead and wouldn't take a charge. So I bought a new battery and put it in and turned the key...and nothing happened. No lights, nothing. Idk where to even start looking or what it could possibly be.
Any ideas???
And yes it is the correct battery and the new battery is good. Had it tested.
MV_Rookie_128 is offline
post #2 of 14 (permalink) Old 03-25-2013, 01:12 AM
MVAgusta.net Sponsor
mitchy's Avatar
Sorry,I have to ask is the battery connected properly.Meaning positive/negative terminals are correct.Have you checked the fuses?Is the fuel pump going through it's test cycle when you turn the ignition on,or is that dead too.
Bike- F4 1078 312rr
Work.Email & Paypal.
Work Phone (+61)0755244655
Facebook- Mitch Covington
Mobile-0423041326
mitchy is offline
post #3 of 14 (permalink) Old 03-25-2013, 01:46 AM
+10 on what Mitch said. Then when you finished correcting the error. Replace the 40A fuse on the Starter solenoid and hope you didn't blow the diode.
post #4 of 14 (permalink) Old 03-25-2013, 05:10 AM
Well, Rookie, as a friend once said to me: "Check what you did last, before the problem, that's what you need to fix."
It is likely that you installed the battery with its polarity reversed. There are many threads on the subject, and many people who continue to do this. The battery is supposed to be installed on its side with the negative terminal forward. Batteries for this bike will install quite nicely with the terminals up and the negative at the rear leading to connection at the wrong poles.
Hopefully, as Mitch and Dons have mentioned, you just need to pull the battery and install it correctly and the main fuse protected all else.
post #5 of 14 (permalink) Old 03-25-2013, 09:18 AM Thread Starter
Battery is installed properly. Positive in the back. Neg in front. And no the fuel pump doesn't turn on. I turn the key and its as if I didn't. No lights. No noises. Nothin. Idk how anything could have blown or anything cuz I started it in January and ran just fine. Now I swapped batteries and nothing works.
If its the fuses, where are they located and I'm guessing if they are bad I should expect to have to order them online?
post #6 of 14 (permalink) Old 03-25-2013, 11:22 AM
Did you get all the wiring hooked up?
post #7 of 14 (permalink) Old 03-25-2013, 03:33 PM
trickydicky's Avatar
I know on my 2002 750 there are 2 wires on the negative side and when I changed my battery one of the leads dropped out of sight which is very easy for it to do.
trickydicky is offline
post #8 of 14 (permalink) Old 03-25-2013, 03:57 PM
Rommeld's Avatar
The main fuse is in the box on the left side of your bike when you are sitting on the bike. Just remove the left main fairing panel and you will see it left of your tank.
Isn't the F4 the most beautiful bike you have ever seen?
Rommeld is offline
post #9 of 14 (permalink) Old 03-25-2013, 04:13 PM
mitchy's Avatar
The fuses are a standard mini blade fuse.Any Auto shop will have them.
Bike- F4 1078 312rr
Mobile-0423041326
mitchy is offline
post #10 of 14 (permalink) Old 03-25-2013, 05:20 PM Thread Starter
2 negative 1 positive correct?
