09 F4 will not start - MVAgusta.net
post #1 of 9 (permalink) Old 06-18-2011, 05:02 PM Thread Starter
s72237's Avatar
Need help before Sunday track day. 12.5 volts in batt. Ignition just clicks. I located the relay that is clicking. nothing further. Any help welcomed.
s72237 is offline
post #2 of 9 (permalink) Old 06-18-2011, 05:46 PM
quad-turbo's Avatar
Battery not charged enough, full charge is approx 13.7
ORBIS NON SUFFICIT
quad-turbo is offline
post #3 of 9 (permalink) Old 06-18-2011, 06:16 PM Thread Starter
s72237's Avatar
Yes thanks it jumps but will not hold charge. Great timing.
s72237 is offline
post #4 of 9 (permalink) Old 06-18-2011, 06:25 PM
mv2envy's Avatar
Jump it from your car, see if it will start. Does the started run when you try to start? Does the fuel pump prime when you open the key?
Joe - mv2envy
AKA. MV Guy 12345
mv2envy is offline
post #5 of 9 (permalink) Old 06-18-2011, 09:03 PM
SportBikeMike's Avatar
Have you recently removed the battery? Assuming the '09s are the same as the '07s, there are actually FIVE connectors to the battery.....I believe three to negative, and two to positive.
'07 MV Agusta F4 1000R
'97 Ducati 916
SportBikeMike is offline
post #6 of 9 (permalink) Old 06-18-2011, 10:51 PM
limp battery?
check the 40 amp fuses on the back of the starter solenoid, one is working the other is a spare.....
post #7 of 9 (permalink) Old 06-19-2011, 03:33 PM
Sounds like a bad battery. One way to check is keep the voltage meter on the battery as you try to crank it. If it drops to some really low voltage like 6 or 8 then the battery is not charged and maybe toast.
Jim
Capo is offline
post #8 of 9 (permalink) Old 06-19-2011, 04:21 PM
Could be the alternator. Check the voltage across the battery with the engine running, should be 13 plus volts.
Keep one wheel down!
No MV's in the garage anymore
john is offline
post #9 of 9 (permalink) Old 06-20-2011, 01:20 AM
clicker?
John;
it has to be higher than 13v a fully charged lead acid battery is ~13.2
the manual has charging voltage higher ~14v to almost 15v, temp dependent
s72237;
like i said before check the alternator 40amp fuse......bet its blown there are 2, one is a spare
start it, put a DC volt meter across the battery, if at 4,000 rpm you don't see 14+ volts its not charging
