microtec and Dyno ???????? - MVAgusta.net
post #1 of 27 (permalink) Old 06-07-2011, 10:00 PM Thread Starter
juan felipe rodriguez's Avatar
Friendly good morning:
Recently they installed dyno in my city, I am going to install my new Ecu microtec in my mv 2007 .y I want to ask to them friendly you that they give an advice:
it is necessary to place the motorcycle in dyno after installing microtec? friendly the person who handles dyno says to me that there is no necessity to clear my PC? I have understood that if there is to clear the PC after to install microtec, that I can do? I am thankful to them give its advice me.
greetings
JUAN
juan felipe rodriguez is offline
post #2 of 27 (permalink) Old 06-07-2011, 11:16 PM
Exclamation -10
Juan, you have Microtec ECU, take the Powercommander OFF.
PC is not neccesary. Have you got map on Microtec ECU ?
post #3 of 27 (permalink) Old 06-07-2011, 11:25 PM Thread Starter
FRIEND DONSY
I ONLY HAVE WHAT CHRIS SENDS THE MICROTEC, CABLE OF DATA AND SOFWARE AND THE INSTRUCTIONS FOR THEIR INSTALLATION
THAT YOU THINK?
GREETINGS
JUAN
post #4 of 27 (permalink) Old 06-07-2011, 11:28 PM
Hi Juan
What PC are you talking about ?
post #5 of 27 (permalink) Old 06-07-2011, 11:33 PM Thread Starter
FRIEND DONSY
AND AS I CONNECT QUICK SHIFTER IF THIS CONNECTED TO THE PC?
GREETINGS
JUAN
post #6 of 27 (permalink) Old 06-07-2011, 11:36 PM
Worry about the quickshifter later. You MUST remove the PowerCommander first Juan. Quickshifter connects to microtec ECU.
post #7 of 27 (permalink) Old 06-07-2011, 11:40 PM Thread Starter
ok donsy
but you that says are necessary dyno? or only estara well installing microtec
greetings
Juan
post #8 of 27 (permalink) Old 06-08-2011, 01:52 AM
PP1098's Avatar
Juan, I would suggest talking to Chris about this he knows what to do.
In my case everything (fuelling maps) came ready with the Microtec ecu. However I did run a dyno test only to fiddle the mixture at low revs. I had loud bangs and flames from the exhaust on the overun (closed throttle) and dyno sorted it out quickly.
You can run a dyno test before the microtec ecu only to show you how much bhp the bike makes (and air /fuel ratio in all revs). However you can not change sth (unless you use the microtec ecu or the Power Commander on the bike).
PC (personal computer?) you will need to install the microtec software and tune the mixture.
Quickshifter I have no idea how this works with the ecu.
I agree with comment above, Power Commander is not needed. It does what Microtec ecu does. Its either the Power Commander (PC) or Microtec. And Microtec ecu is much better than the PC in our case.
Phil
PP1098 is offline
post #9 of 27 (permalink) Old 06-08-2011, 07:22 AM Thread Starter
Phil
thanks friend PP1098
its then explanation is very clear that hare, when microtec has ready my I them estare making question by.
again thanks and excuse my English is by means of a translator
greetings
JUAN
post #10 of 27 (permalink) Old 06-08-2011, 07:36 AM
spypyp's Avatar
you do not have to disconnect the power commander as we found out.
spypyp is offline
