help electronic problem F4 - MVAgusta.net
post #1 of 9 (permalink) Old 06-01-2011, 07:42 PM Thread Starter
Send a message via Skype™ to Hordursp
hello i got an F4-1000-s 2005model
and last time i whas out riding i stopt for a chat and killd the engine with the emergency stop and the lights whare still on like normally
and then i heard a snapp and the dashbord whent blank no lights or anything and the parklights went blank to, but the bike runs fine
i keep blowing this fuse "C-3 7,5Sidelights, mileometer sensor, fuel tank sensor" 7,5A
i cant see any short circuit or anythin where the positive could touch the negative wire...
have anyone of you had this problem?
bestregards from Iceland: Hrur Snr
Mv Agusta F4-1000-2005
Aprilia SXV550-2007
Suzuki rgv250m
Hordursp is offline
post #2 of 9 (permalink) Old 06-01-2011, 09:26 PM
kieran323's Avatar
Check your earth wires mate to start with
"You live more for five minutes going fast on a bike than other people do in all their life" #58
kieran323 is offline
post #3 of 9 (permalink) Old 06-01-2011, 10:42 PM
Thumbs down wires?
Kieran;
a loose ground won't blow a fuse, it will keep things from working though
a bad positive wire..... abraded to ground will blow a fuse
Hordursp;
fuel tank plug wires, the most likely to get pinched are probably the problem
i doubt it's inside the tank, do you have a multimeter?
key off, check both sides of the fuse holder for connection to ground, then disconnect the different circuits one at a time
i'd disconnect the speed sensor 1st
post #4 of 9 (permalink) Old 06-01-2011, 10:50 PM
kieran323's Avatar
Retract my statement.
post #5 of 9 (permalink) Old 06-02-2011, 07:04 AM
lee
lee's Avatar
If it was fine before you used the kill button and not fineafterward then I'd be looking at the switch and trace it's wiring. Even god doesn't know how the wiring is on these things but I'm inclined to think it has something to do with the switch/wiring/relationship to other stuff that no longer works.
lee is offline
post #6 of 9 (permalink) Old 06-02-2011, 11:21 AM Thread Starter
Thanks boys when i disconnect the speedsensor i get all the things to work, so the problem must be in the speedsensor.
Aprilia SXV550-2007
Suzuki rgv250m
Hordursp is offline
post #7 of 9 (permalink) Old 06-02-2011, 10:17 PM
mv2envy's Avatar
that or you pinched the wires that lead to the speed sensor.
Joe - mv2envy
AKA. MV Guy 12345
mv2envy is offline
post #8 of 9 (permalink) Old 06-02-2011, 10:38 PM
short?
Hordursp;
inspect the wires going to the speed sensor......
that's why i said to unplug it, there are so many places it could be damaged
glad it was simply unplugging it......now you know the bad circuit
post #9 of 9 (permalink) Old 06-07-2011, 09:39 PM Thread Starter
thanks a million, i just pinched the wires or the chain did.
Aprilia SXV550-2007
Suzuki rgv250m
Hordursp is offline
