RexXer ECU Programmer - Anyone? - MVAgusta.net
post #1 of 7 (permalink) Old 05-25-2011, 10:20 AM Thread Starter
dml
dml's Avatar
Hi all
Does anyone reprogrammed their ECU with this?
http://www.rexxer.eu/e_produkte.cfm
dml is offline
post #2 of 7 (permalink) Old 05-25-2011, 10:58 AM
X81
Originally Posted by dml View Post
Hi all
I briefly looked into this stuff a few years ago. In the end i think i didn't have the adjustment levels that i was after and the cost for what it could offer was not as good as the Microtec stuff.
At the time i looked into most things available and always ended up back at Microtec.
There isn't much info on that site of exactly what it will allow you to do for each type of bike and what info there is gives the impression that you only install prewritten maps and don't have full access to do your own mapping..............well not without spending a few thousand euro's.
Unless i've read it wrong of course which is entirely possible.
X81 is offline
post #3 of 7 (permalink) Old 05-25-2011, 10:59 AM
MV-999R's Avatar
Never heard of it.
Better go with Microtec
MV-999R is offline
post #4 of 7 (permalink) Old 05-25-2011, 11:02 AM Thread Starter
dml
dml's Avatar
Yes poor info on the site...
I was just checking... MicroTec is the way to go!
dml is offline
post #5 of 7 (permalink) Old 05-25-2011, 05:00 PM
revhead1957's Avatar
What a shame there isn't a service that allows flashing of the stock ecu to allow minor alteration for local conditions/temperatures/fuel.
I had the misfortune to get caught in a traffic jam and found out firsthand that the low speed first gear crawl is virtually impossible on this bike, particularly as it heats up. I am quite happy with the running in other conditions and situations. I do not require more hp, and do not plan to spend mega $ on cat removal etc.
I have spent the last few nights trawling the net, looking for the likely cause of this issue and low cost solutions (AU$200 would seem reasonable to me) It gets interesting, as you find someone making a statement that appears plausible, you can find another saying the exact opposite!
I don't need it to be perfect, I just would like it to be more rideable in that situation. (lights, roundabouts etc)
Conclusions so far:
The area that needs adjustment is the low end range where the o2 sensor is controlling things. The exhaust flapper is closed too.
Solutions considered:
Add a secondary IAT sensor (switched on in hot temp or round town) with a more resistance to force the ecu to richen the mix? Not possible unless the plugs can be sourced (don't want to cut the loom).
Reposition the IAT sensor to an area where it doesn't get the heat buildup? Currently it sits above the header tank and gets all the rising heat from the radiator. I note the F4 has the sensor in the air intake tract.
Alter TPS to the upper and of the range to achieve the same?
PC? - doesn't work in the low end unless major mods to disable the o2 sensor and ignore the error code.
Jam the flapper open and disconnect the cables? Haven't thought this through yet, but I doubt this would fix the issue, as I think the flapper doesn't open until later in the range.
Whilst I understand the designers' needs to economically produce a system for the whole world that covers all conditions and epa laws, it would be nice to be able to make small adjustments.
Thoughts?
revhead1957 is offline
post #6 of 7 (permalink) Old 05-26-2011, 08:01 AM
X81
Conclusions so far:
Thoughts?
Or fit a Microtec and have full control of everything with no need to jam anythign open, find a work around for 02 sensors etc or live with error codes.
X81 is offline
post #7 of 7 (permalink) Old 05-26-2011, 05:07 PM
Thanks Chris, but that's big $ for a minor tweak.
Yes, I know, I'm cheap, but I am 95% happy with the bike as it is.
