coolant problems - MVAgusta.net
post #1 of 6 (permalink) Old 05-18-2011, 04:26 PM Thread Starter
rpm
rpm's Avatar
coolant problems
hello my 312r trows out water when going slow also going pretty hot.is it enough to change the impeller how many degrees does it go down.
rpm is offline
post #2 of 6 (permalink) Old 05-18-2011, 04:28 PM
AF Agusta's Avatar
my bike decreased an average of 10-15 degrees F in and around town after changing out the impeller and using engine ice
AF Agusta is offline
post #3 of 6 (permalink) Old 05-18-2011, 04:37 PM
make sure the system is properly bled before you make expensive changes.
Most ain't.
post #4 of 6 (permalink) Old 05-20-2011, 10:15 AM
Potnoodle's Avatar
Send a message via MSN to Potnoodle
I just put the new impellor and pump housing in from MV, which was cheaper than Vesuvio racings option, and along with ice i havent overheated yet, not been above 100.
2010 - RSV4
2009 - F4 1000R
2009 - GSXR750
2008 - F4 1000R
2008 - F4 1000S
2007 - F4 750
Potnoodle is offline
post #5 of 6 (permalink) Old 05-20-2011, 04:52 PM
chay250's Avatar
my 312r used to pee coolant all the time - bleed the system - cured my problem.
colin
chay250 is offline
post #6 of 6 (permalink) Old 05-21-2011, 05:09 AM
craigoz's Avatar
My top radiator has finally started leaking, anyone know a radiator reparier in Australia worth conatacting? Is the upgraded radiator still cracking? is it worth getting? How much $$ and from where, parts here in Oz are rediculas price, what about bigger water pump upgrade?
craigoz is offline
