F4 shock options - MVAgusta.net
post #1 of 19 (permalink) Old 05-12-2011, 02:05 PM Thread Starter
Submariner's Avatar
F4 shock options
Guys,
I am considering changing the shock on my bike but do not want to go 'aftermarket'. I am a bit confused on F4 shocks available so would appreciate some guidance.
What is the difference in performance (if any) between the shock on my bike F4 750cc 2000 (which has rings to adjust the preload) and the type that appears to have hydrallic adjustment?
What year did the hydrallic adjustment shock come into use and what year was it replaced?
I am considering an F4 1000 2007 shock, Brutale 2009 and 1000R shock but am simply not sure whether or not they are different / the same etc.
Sub
Submariner is offline
post #2 of 19 (permalink) Old 05-12-2011, 10:21 PM
mv2envy's Avatar
Just get the Ohlins, dont bother with the shock from a 1000. They suck just as much as yours does.
Joe - mv2envy
AKA. MV Guy 12345
mv2envy is offline
post #3 of 19 (permalink) Old 05-13-2011, 04:25 AM
mshermanator's Avatar
I fitted a technoflex shock, it has been very good, not a problem at all and handles whatever is thrown at it
Harden Up
Previous bikes
CB250 NT
VT250 FT
VF500
FJ 1000
R100RS
R1100RS
R1100RT
R1100s
750 Brutale
F4 750 evo3
F4 1000s
S1000rr 2012
S1000rr 2013
mshermanator is offline
post #4 of 19 (permalink) Old 05-13-2011, 09:30 AM
number2's Avatar
I just installed a Bitubo. Made in Italy and distributed in the States by PJs parts. Top quality. You do NOT want a Sachs OEM shock. They are crap
number2 is offline
post #5 of 19 (permalink) Old 05-13-2011, 12:08 PM Thread Starter
Submariner's Avatar
Guys, I want to stick with the OEM shock
post #6 of 19 (permalink) Old 05-13-2011, 12:13 PM
mv2envy's Avatar
I can sell you my rear shock if you want, its been reworked and revalved by RaceTech. Thats the best performance you will get from a factory shock.
Joe - mv2envy
AKA. MV Guy 12345
mv2envy is offline
post #7 of 19 (permalink) Old 05-13-2011, 12:22 PM
There's a shock from a F4 on UK ebay at the mo Sub, nothing to do with me I hasten to add.
Keep one wheel down!
No MV's in the garage anymore
john is offline
post #8 of 19 (permalink) Old 05-13-2011, 01:28 PM Thread Starter
Submariner's Avatar
I know fella, its from Mark at Time machine who I think is a pretty decent fella. I am simply tring to understand the differences between the hydrallic and non-hydrallic types
post #9 of 19 (permalink) Old 05-13-2011, 02:03 PM
Jeffy's Avatar
All of the shocks are hydraulic, meaning that oil is forced through holes and around shims to create damping forces. What you are referring to is the spring preload adjuster. Some use a threaded collar and some use hydraulic fluid to move the collar. All hydraulic preload adjustment is is an easier way to adjust spring preload - It has nothing to do with the actual shock performance. The real difference bewteen shock models are the valving inside, spring rate of coil spring and range and type of damping adjustments. All of those will vary on OEM shocks from year to year depending on who supplied the shock or what MV asked for in the shock.
So, knowing the real difference between the OEM shocks and how they perform may not be very straight forward.
Jeffy
08 MV F4 312R
02 Duc 998
-Ride fast, ride safe, ride well
Jeffy is offline
post #10 of 19 (permalink) Old 05-15-2011, 04:50 AM
No there is (was) another one. Last time I looked it was at 50 with 1 bid.
john is offline
