F4 Clutch requiring replacement - MVAgusta.net
 2Likes
post #1 of 27 (permalink) Old 08-30-2010, 09:15 AM Thread Starter
Submariner's Avatar
People,
Been out today for a quick spin. In 5th and 6th gear at around 9000 rpm I get an increase in revs but no increase in speed. To me this sounds like a knackered clutch. I have been riding in traffic quite alot today.
The manual makes no reference to clutch replacement and I presume such a problem wont 'go away'
I have done a search on here and can find no threads which address the following - Can anyone advise on a good supplier of a clutch replacement kit in the UK and also if there are any 'nice to knows' when undertaking replacement?
Sub
Submariner is offline
post #2 of 27 (permalink) Old 08-30-2010, 09:45 AM
stargateuser's Avatar
I can't help, that's one problem I haven't yet had the pleasure of - sorry mate!
F4 1000R
Louder, faster and fixed
The bike wants me to miss the TT but I'm not going to let it!
stargateuser is offline
post #3 of 27 (permalink) Old 08-30-2010, 09:55 AM Thread Starter
Submariner's Avatar
The manual says that the part numbers are
800081511 - plates
800081510 - plates
800092482 - springs
post #4 of 27 (permalink) Old 08-30-2010, 10:09 AM
ErikV's Avatar
800081511 - plates
800081510 - plates
800092482 - springs
Is there some special tool needed to release the springs while disassembling and reassembling?
“When I disagree with a rational man, I let reality be our final arbiter; if I am right, he will learn; if I am wrong, I will; one of us will win, but both will profit.”
ErikV is offline
post #5 of 27 (permalink) Old 08-30-2010, 10:13 AM Thread Starter
Submariner's Avatar
It would suggest that, I am hoping that a generic type tool would be sufficient
post #6 of 27 (permalink) Old 08-30-2010, 03:41 PM
Wink
no special tools required;
drain the oil
pull the clutch cover
remove the 4 pressure plate screws
lift the pressure plate
remove the clutch pack
measure the discs
minimum clutch disc thickness 2.8mm
check for warping
bet its the springs.......
if the plates are within spec.....put stiffer springs in or shim the stock ones
inner valve springs are usually about the right size
my KTM Duke ll would light its clutch up.....Triumph triple inners fixed it
minimum spring length 57.9mm
PM the CAG for a clutch pack if you need one
post #7 of 27 (permalink) Old 08-30-2010, 03:42 PM Thread Starter
Submariner's Avatar
Cheers Knurl
post #8 of 27 (permalink) Old 08-30-2010, 04:13 PM
MvMerito's Avatar
does this mean it wont be ridden to the office after all. Just think, 1 day you dont know how to park it, the next its clutch surgery. Its all rock and roll with you mate
theknurl likes this.
MvMerito is offline
post #9 of 27 (permalink) Old 08-31-2010, 06:22 AM Thread Starter
Submariner's Avatar
lol
post #10 of 27 (permalink) Old 08-31-2010, 08:07 AM
Totale's Avatar
You haven't been putting any 'Special' oil (or additives) in it have you...
Totale is offline
