A BOLT from the blue...luck prevails! - MVAgusta.net
post #1 of 21 (permalink) Old 07-21-2010, 06:15 PM Thread Starter
Well, I was out for a spirited ride last week, testing suspension and tires. We stopped for a break and to discuss destination and I just happened to look down at my right boot. Something just didn't look to be correct. The pictured bolt, which holds the swingarm pivot in place, had backed out and was only being held by three threads...
It was so loose that it was easily turned by hand. Now, this bolt has a 20mm head...where the feck does one find a 20mm socket (yes, it's recessed) in the middle of East Bumf*ck! A riding bud had a multi-tool and I used it improperly to at least seat the bolt. Tonight, I was reminded of this as I was putting the bike back together after installing a Melotti Tail Tidy, Rizoma Turn Signals, and a Carbon Fiber Heat Shield...sweet looking addition by subtraction. Anywho...I torqued the offending 20mm bolt tonight to its proper 70-75Nm.
The offending bolt...CHECK YOURS!!!
Heat Shield with Thermo Barrier
Heat Shield
Nice Signals
Bright TOO!
post #2 of 21 (permalink) Old 04-14-2013, 03:18 PM
Maximum Velocity's Avatar
Thanks for the tip! And nice bike btw!!!
What a beast of a motorcycle!
Maximum Velocity is offline
post #3 of 21 (permalink) Old 04-14-2013, 03:20 PM Thread Starter
Thanks, and you are welcome....Andrew just had a bit of a problem with this too.
post #4 of 21 (permalink) Old 04-14-2013, 03:26 PM
R1andrew's Avatar
I was not as lucky and lost my bolt and spacer. Not sure about Chuck but I have had my bolt out. So I am going with it was my fault. Must not have tighten it correctly.
R1andrew is online now
post #5 of 21 (permalink) Old 04-14-2013, 03:47 PM Thread Starter
Mine had not been touched since new....now it gets checked regularly!
post #6 of 21 (permalink) Old 04-14-2013, 04:35 PM
R1andrew's Avatar
When my new one comes in it will have lock tight on it this time.
post #7 of 21 (permalink) Old 04-14-2013, 06:16 PM
Wink
LocTite is not a "Positive Locking Device"
according to the FAA and most racing associations
post #8 of 21 (permalink) Old 04-14-2013, 07:30 PM
R1andrew's Avatar
So what is? I could use jbweld
post #9 of 21 (permalink) Old 04-15-2013, 04:19 AM Thread Starter
I believe Noel is a proponent of proper torque....and lockwire.
post #10 of 21 (permalink) Old 04-15-2013, 05:14 AM
gotojoe's Avatar
When a man rides a Jota he gets to checking his nuts as routine
gotojoe is offline
You may post new threads
You may post replies
