Side stand modification?? - MVAgusta.net
post #1 of 8 (permalink) Old 07-16-2010, 12:49 AM Thread Starter
Hey,
this springy side stand on the F4 is driving me up the wall, I've nearly dropped her a few times now.
Is there any modifications that can be done to make it stay down - like a normal stand. Removing the spring is a no go as it'll just flap about.
Any advice would be welcome.
D
dangerousdave is offline
post #2 of 8 (permalink) Old 07-16-2010, 01:00 AM
minime's Avatar
You can get a different C bracket?? (don't ask me what the technical name is), off either a later model 750 or 1000 or even Ducati 916. You see them on ebay time to time. This will stop the side stand from springing up automatically.
minime is offline
post #3 of 8 (permalink) Old 07-16-2010, 01:01 AM
Pfatty's Avatar
Yes it can be modified. You'll find info at
mvfaq.blogspot.com
Have a look through there, lots of useful info.
Simon
Pfatty is offline
post #4 of 8 (permalink) Old 07-16-2010, 07:24 AM
I modified mine using a block of wood and a hammer. I just gently tapped on the bottom of the C bracket until the sprung point was bent passed the stop pin. Now it will stay down.
Si
TheCatWhisperer is offline
post #5 of 8 (permalink) Old 07-16-2010, 01:35 PM
automatic side stand
you need part# 800098707.....
TheCatWhisperer; hey don't use a chunk of tree and a BMW tool on your MV ....lol
post #6 of 8 (permalink) Old 07-17-2010, 01:47 PM
smilo996's Avatar
Hi,
I have just replaced the side stand that broke on my bike. The new one came with the spring and bracket, so if you need it I think I have the spring and other bit from a 2009 312.
Rgds
Ian
If Ducati bought MV then Rossi could finish his career on a Ducati and then go to WSB on an MV. We Wish......
smilo996 is offline
post #7 of 8 (permalink) Old 07-17-2010, 02:54 PM Thread Starter
Spent a few hours this morning making a new crescent shaped piece out of 4mm galvanised, instead of the straight one.
Worked a treat at zero cost.
I'll post some pictures
post #8 of 8 (permalink) Old 07-18-2010, 08:43 AM
lee
lee's Avatar
I "notched" out the stand where it bears when down enough to allow it to go more fwd. Also made a new curved piece to clear the spring and stand. Let's it overcenter more.
Because the stand is now more fwd the bike has more lean to it ( too much lean stock anyway) so i made a little shoe which goes under the base pad on the stand to get the bike more up right.
lee is offline
