best exhaust for F4 1078 - MVAgusta.net
post #1 of 11 (permalink) Old 07-15-2010, 08:09 AM Thread Starter
firedancer's Avatar
i am a bit confused and would appreciate any help.
i want to reduce the heat on my new F4 1078 312 RR, and i am planning
to remove the cat. as i like the look of the original pipes i will certainly
keep the four organ pipes. so i am looking in getting the set
http://www.mvagusta.it/common/shop/s...atori-rg3--ecu
but somehow i cant figure out what is the difference between the RG3
exhaust and the stock one. especially, i am worried that it is much
louder. i would like to stay below the 100 db limit to avoid having
problems on race tracks and with the people in green uniforms.
any other "must" upgrades to further cool the bike?
-- engine ice, but i am unable to find a distributor here in germany
-- is it correct that the bike has already the improved water impeller?
-- does a better air filter help?
-- and no, drilling holes into the fairing is not an option
firedancer is offline
post #2 of 11 (permalink) Old 07-15-2010, 08:31 AM
MikeF4Black's Avatar
Cool
FD: I've got the "old" (non-slash tips) stainless RG3's (with the MV race ECU) on my 1078, with the Arrow header/midpipe combo, and they are a bit louder than the standard pipes of course. They were measured at 95 dBA at Park Zandvoort circuit last year, at appr 1m, 6000rpm. I just scraped through and did the trackday.
Check if your bike has the improved factory impeller; I've had no problems since having it installed, and no need for further mods. It still runs hot, but even in the current hot weather it doesn't overheat, in all sorts of traffic situations. No flashing numbers, just hot.
Hope this was helpful.
Nulla tenaci invia est via
MikeF4Black is offline
post #3 of 11 (permalink) Old 07-15-2010, 10:30 AM
AEI
AEI's Avatar
Hi firedancer,
I reply in english with respect to all other forum members that do not speak german.
I have the same bike ( F4 1078RR ) and changed the complete exhaust to inox RG3 and Agusta race ECU.
The complete exhaust is inox and has no cat anymore.
I will also do the water pump upgrade at my next service.
This two things alone will keep the engine temperature even on hot days and high rpm below 110 degrees celsius.
Where did you buy your bike?
AEI is offline
post #4 of 11 (permalink) Old 07-15-2010, 10:45 AM
khameron's Avatar
The MV impeller upgrade will lower the max temp by 10°C.
You can get it here if you want http://www.vesuvioracing.com/Water-p...cs---5200.html
khameron is offline
post #5 of 11 (permalink) Old 07-15-2010, 12:17 PM Thread Starter
firedancer's Avatar
ok, great and thanks for the info so far. the question i have now is:
how i can find out whether the bike has the new impeller or not?
are there any different markings on the housing?
post #6 of 11 (permalink) Old 07-15-2010, 12:25 PM Thread Starter
firedancer's Avatar
Originally Posted by AEI View Post
Hi firedancer,
i did get it from the local store here in stuttgart, Gerhard Mörk,
as i was very satisfied with their service when i bought the brutale.
but the bike runs a bit hot, and i would be happy to cool it down a bit.
und grüsse nach bayern
post #7 of 11 (permalink) Old 07-15-2010, 12:36 PM
Cool
Ask Herr Mörk?
post #8 of 11 (permalink) Old 07-15-2010, 12:38 PM
Cool
Na ja, dann hab'ich die Nase voll....
post #9 of 11 (permalink) Old 07-15-2010, 12:45 PM
Banned
Have a look on ebay at item 110556410408 your problems are over and they are cheap.
stephen wood is offline
post #10 of 11 (permalink) Old 07-15-2010, 11:44 PM
AEI
AEI's Avatar
Get the inox or titan exhaust system without cat. This will cut down max. temp most.
Water impeller will drop it down by another 10°C.
My dealer said my 1078RR from 2009 does not have the water impeller upgrade. It´s an race part and has to be changed with the stock impeller extra.
Only changing the exhaust to RG3 or similar system without cat will solve the problem mostly.
Performance and sound is also better!
AEI is offline
