rg3s set up - MVAgusta.net
post #1 of 15 (permalink) Old 07-14-2010, 02:42 PM Thread Starter
chay250's Avatar
rg3s set up
hi - question - have R312 with the cat removed would the bike run ok if i fit rg3s only without modifications to the fueling?- i have just contacted vesuvio who say if i fit rg3s i would req a new e.c.u. - others say they replaced the eprom only.
i am confused to be honest as i have read a lot of the old threads on this subject and opinions seem to vary.
chay250 is offline
post #2 of 15 (permalink) Old 07-14-2010, 02:47 PM
Cash_Dawg's Avatar
Change the ECU and get some custom mapping done while doing some testing on a Dyno. That way you will ensure that you dont have any issues with fueling down the track and also be able to gain the best performance out of your 312R and RG3's
_________________
A closed mouth gathers no feet.........
Cash_Dawg is offline
post #3 of 15 (permalink) Old 07-14-2010, 03:51 PM
progress72's Avatar
no eprom on ECU E3. The Marelli 5SM il welded.
You have 3 choice:
1. buy a new ECU Mv Corse
2. upload the new map in your ECU (only in MV assistance)
3. buy a full open ECU like the Microtec M191 or M226 (new)
You must use a new map because the exhaust is open now! The A/F ratio is changed!
The Marelli 5Sm is not possible to map on a Dyno, is only possible upload a map!
progress72 is offline
post #4 of 15 (permalink) Old 07-14-2010, 04:08 PM
number2's Avatar
actually there is another choice. A PCIII
number2 is offline
post #5 of 15 (permalink) Old 07-14-2010, 04:23 PM
progress72's Avatar
not on a euro3...
the PCIII don't is an ECU but it shift the base plane of map...the range of rpm is big and not exact like a full open ECU....
I think that is the worst solution for an MV!
post #6 of 15 (permalink) Old 07-14-2010, 04:38 PM
You say the cat is removed, do you still have the Lambda probe connected?
If not either your bike is either fitted with a new ECU or the probe has been fitted with an eliminator.
I replaced the ECU with the RG3 Race ECU, they come up second hand here for time to time. With the race ECU the Lambda probe is redundant and a PC III can be fitted (or the ECU tuned) for final tweaking of the fuelling curve.
With the OEM ECU, unless the Powercommander can also replicate the exhaust (Lambda probe) the 5SM ECU and PC III will continually be fighting.
What I mean is every time the PC III adjusts the mixture the Lambda reading will also change resulting in the OEM ECU also changing the mixture to obtain the originally desired value - net result the PC III does nothing (it is a little more complex than this but that is the gist of the issue).
In summary, with the OEM ECU the bike will run with RG3 pipes, however if the ECU is also changed, it will run a whole lot better.
Andrew...
andrew is offline
post #7 of 15 (permalink) Old 07-14-2010, 04:53 PM
mv2envy's Avatar
There is another option, Fast By Ferracci will do a swap for your ecu. You send them yours, they send you a race ecu.
Joe - mv2envy
AKA. MV Guy 12345
mv2envy is offline
post #8 of 15 (permalink) Old 07-15-2010, 12:37 AM
Tocalosh Black's Avatar
speak with chris at xbikes, i think he is the most knowledgable on these matters at present 01945 585533
Tocalosh Black is offline
post #9 of 15 (permalink) Old 07-15-2010, 03:48 AM Thread Starter
chay250's Avatar
thanks for the tip - will give chris a ring as there are obviously differing opinions on this subject
chay250 is offline
post #10 of 15 (permalink) Old 07-15-2010, 04:17 AM
progress72's Avatar
the MV Corse race ECU (5SM) use the same firmware of Euro2....and lambda is disabled.....you don't need use it or a terminator, just a plug!
