lifting the tank - MVAgusta.net
post #1 of 5 (permalink) Old 06-21-2010, 05:44 AM Thread Starter
Submariner's Avatar
lifting the tank
People,
I have fault on my 2000 F4 which after advice on a previous post suggests could be either a fault in the fuel pump or the wiring to it shorting to the chassis or tank.
As the fault appeared immediately after hitting a bump in the road combined with the fact that the pump does run (albeit drawing enough current to blow a 30A fuse) I am beginning to think there could be an intermittent or permanent short to ground via a chaffed or crushed wire.
There is a 4 pin connector and wiring just before the fuel pump which I intend wiggling to basically see what happens. I call this method the ‘poke and hope’ approach.
Can anyone advise how much ‘rattle room’ can be created by unbolting the tank prior to removing any petrol lines etc.? I don’t really want to disconnect petrol lines but would like to create some wiggle room.
I am hoping I can lift the tank say 4 to 6 inches and hold it up on wooden blocks to help me to eliminate / find a wiring fault.
Sub
Submariner is offline
post #2 of 5 (permalink) Old 06-21-2010, 05:55 AM
jimboF4's Avatar
Hi Submariner,
Yep there is justa bit of wiggle room if you unbolt the tank mouts and securing bolt, it is a bit difficult as th tank is rather "high" and does fit down between teh frame rails fairly snug.
I would suggest disconnecting the fuel pipes, its not too hard even single handed. Just be careful of teh brittle fuel connectors if they are the original black and white ones.
Regards
Jimbo
jimboF4 is offline
post #3 of 5 (permalink) Old 06-21-2010, 09:21 AM
JS Agusta's Avatar
I like to put some tape on the top front edge of the tank. This is the seam You see when sitting on the bike. This forward most part (air box) stays when You lift the tank. Tape both tank & air box to eliminate chips. While Your at it change those fuel line fittings to metal ones.
2014 B3 ITALIA
2010 Aprilia Tuono sold
08 Ducati 1098S
06 Ducati 999S sold
Bimota Santa Monica
2004 R1150RS
2005 MV F4 BLUE & Silver Sold
2010 Aprillia RSV4 R White:sold
1978 BMW R100RS sold
2008 Ducati SC 1000 S Sold
JS Agusta is offline
post #4 of 5 (permalink) Old 06-21-2010, 12:51 PM
Tocalosh Black's Avatar
The tank can be lifted to create a good 6 inches of room, rest the 'c' grab bolt things on the lower edge of the air box and the rear of the tank on the battery tray, fits snugly and securely so you can play around underneath it......................copyright of C.Wells 2010 (xbikes)
Tocalosh Black is offline
post #5 of 5 (permalink) Old 06-21-2010, 04:12 PM Thread Starter
Submariner's Avatar
thanks guys managed to lift it. May actually have to remove it dont know yet
