F4 problems - MVAgusta.net
post #1 of 8 (permalink) Old 06-21-2010, 02:58 AM Thread Starter
jwslofstra's Avatar
F4 problems
So here is the story...
I got a RG3 and open midpipe installed with a Rapid bike, so the bike would be set perfectly in therms of fuel consumption etc.
Yesterday I made a ride with some friends, they told me that if I open the throttle, start accelerating and close the throttle is starts smoking from the exhaust for like 5 seconds.
When the bike is idling at random intervals I hear some kind of knocking noise coming from the engine or nearby the engine.
Sometimes the engine just stops without any reason at all, doesn't matter if the engine is warm or cold, but mostly when the engine is warm.
Any idea's what could be wrong?
MV Agusta F4S EVO3
MV Agusta SPR (crashed
MV Agusta 350 Ipotesi
MV Agusta F4 1000 S (sold)
Suzuki GSX R 1000 (sold)
jwslofstra is offline
post #2 of 8 (permalink) Old 06-21-2010, 03:12 AM
Dont worry about the knocking, it has probably always done it but you have only noticed due to looking for a problem. My bike sounds like a bag of spanners at all times but runs superb.
The smoke from the exhaust & stalling sounds like the fuelling needs setting up properly. If it runs okay off the throttle & through the gears then you most certainly have no mechanical issues.
Taking the cat out of any system makes a big difference to any bikes fuelling but MV"S seem to be affected worse than others due to the standard fuelling been so bad!
bungle is offline
post #3 of 8 (permalink) Old 06-21-2010, 03:54 AM
Upgrading the exhaust has no effect on the mechanical elements, if there is an engine internal mechanical knocking now there was one before. However the revised exhaust may have intorduced a rattle or a component may now have a sympathetic rattle.
What is a "Rapid bike"?
The exhaust modifications you've made will improve the flow from the engine, resulting in lean running (if nothing else is done). I'm assuming a Rapid bike is some kind of ECU modification (or power commander) that richens the mix to appropriately tune the engine.
Smoke for the exhaust isn't really an issue, however under hard acceleration expect some black smoke. Snapping the throttle shut will sometimes result in unburnt fuel being released (usually with some accompanying noise) but may also result in a black or brown haze from the exhaust. If the smoke is blue then your engine may be worn.
From your description, the bike needs more tuning (with respect to the fueling) the bike should still idle cleanly and not stall when closing the throttle.
Andrew...
andrew is offline
post #4 of 8 (permalink) Old 06-21-2010, 03:59 AM
mv2envy's Avatar
Try a RG3 eeprom chip. That might take care of he fueling problem.
Joe - mv2envy
AKA. MV Guy 12345
mv2envy is offline
post #5 of 8 (permalink) Old 06-21-2010, 05:36 AM Thread Starter
jwslofstra's Avatar
There is a RG3 Eprom inside but the problem with that was that the engine was using a lot of fuel (about 1 liter per 8 kilometer).
It was tuned by a MV dealer, but he said he couldn't get the bike to run leaner with this chip.
Rapid bike is about the same thing as a power commander, hope that clears things.
The rapid bike has been installed and set on a dyno test run.
Strange thing about the knocking is that I never heard it before, only yesterday, and the whole exhaust mod is already about 2 weeks on the bike.
MV Agusta F4S EVO3
post #6 of 8 (permalink) Old 06-21-2010, 06:02 AM
Fueling problem
That sounds like your fueling is way off, as well as a few other things. Your bike should not sound like a bucket of bolts, if the pipe is not loose or hitting something then it can be caused by the bad fueling. A bit like knocking in the motor when using wrong fuel on the old carbie bikes.
post #7 of 8 (permalink) Old 06-21-2010, 06:25 AM Thread Starter
jwslofstra's Avatar
Nope, the pipe is not loose, can't find any weak spots at all.
I am not missing any power while accelerating, some in my eyes that means that there is nothing mechanically wrong.
Also thought that maybe one of the sparkplugs is damaged or something, but then again I should be missing power somewhere.
I'll try to contact the dealer again asap.
Anybody who things there is a mechanical failure, please speak your mind, would appreciate it
MV Agusta F4S EVO3
post #8 of 8 (permalink) Old 06-21-2010, 01:01 PM
The_castle's Avatar
Go to a dynamometer operator who is experienced in the Rapid Bike system. Explain the situation. Have them tune the bike.
If you want the best ECU and after sales back up that I'm aware of then contact Chris at X-Bikes. He is a forum sponsor and will no doubt direct you towards the Microtec ECU. Even just a call to get his advice on your current system will most likely be well worth it.
Dave.
The_castle is offline
