Things to weary of on F4 - MVAgusta.net
post #1 of 10 (permalink) Old 06-16-2010, 05:00 PM Thread Starter
celicaman100's Avatar
Hi Guys
Just read about "white312inclt p.o.s" earlier post.
My 2006 F41000R has now got 7,000 miles on the clock.
Have just fitted MV corse Race ECU Decat Pipe & Blue Flame Race cans.
His earlier post has got me worried.
as some of the replies to his posting mention about Cam's peeling ,big ends going at under 12000 miles .
Is there anything I can do to impeed this from happening.
Bike is due for major service @ 8,500 miles so I have been informed by my Mv Dealer.Had last service at 4500.
I do tend to ride it hard but make sure it's warmed up first & Allway's check the levels before each ride.
your input appreciated.
celicaman100 is offline
post #2 of 10 (permalink) Old 06-16-2010, 05:37 PM
Tont's Avatar
My philosphy is don't worry about it till it happens!...I make sure mine is serviced as required, well more frequently than required...and do what you say, check levels and warm up..and I have a good listen to the engine when I get home
Mind you, I've had the rad go a couple of times....not alot I could have done to prevent it though.
If I worried about it, I wouldn't ride it....!
The wife said "Go buy some Art"...
...................__O
................_-\<,_\
...............(_)/ (_)
I bought art.....MV Art!
Tont is offline
post #3 of 10 (permalink) Old 06-16-2010, 05:40 PM
Tont's Avatar
I would add that in my experience with most engines, oil & filter changes are critical, and if you make these more frequent, you will prolong the engine's life.....famous last words, as I have only done 9000 miles....who has covered the most before a re-build then??
Tont is offline
post #4 of 10 (permalink) Old 06-16-2010, 05:58 PM
I think John, Fazer 6, holds the forum record. 50,000 miles or some crazy number like that with no rebuild.
post #5 of 10 (permalink) Old 06-16-2010, 06:12 PM
squibby's Avatar
Service it as per the handbook intervals and you should be ok.
Remember its a hand built engine, and I trust that MV use the finest materials. its no piece of rubbish.
Try not to do any unneccesary servicing either like changing the oil and plugs all the time or just generally trying to fix things that ain't broken. It's either service once a year, or as per the KM/Mile intervals laid out in the manual - whichever comes first, with smaller inspections of chain tension and other minor items regularly.
hate those bike where someone has changed the oil every bloody 1000km or tinkered with it constantly. No offense Tont for all I know you could be right, but each to there own, but some things are best left undisturbed in my opinion including engine oil until a change is required, - usually set by the manufacturer at the optimum interval.
squibby is offline
post #6 of 10 (permalink) Old 06-18-2010, 03:59 PM Thread Starter
Thanks guys
Will stick as per manufactures specifications.
post #7 of 10 (permalink) Old 06-18-2010, 04:02 PM
Thrash the arse off it, thats what they were meant for.
Keep one wheel down!
No MV's in the garage anymore
john is offline
post #8 of 10 (permalink) Old 06-18-2010, 04:46 PM
Rob_b's Avatar
Thumbs up
I agree whole heartedly
Rob_b is offline
post #9 of 10 (permalink) Old 06-18-2010, 05:00 PM
Velocemoto's Avatar
Yep !!
I wouldnt worry about the enigne to much.
It's only excessive track miles that will cause big problems earlier than you think.
..and if you do track an F4, like any other sportsbike, it may need internal work after 3-5000 miles of trackwork. I'm talking hard trackwork at big fast tracks where the engine is on the boil all the time.
I know local MV racebikes had their big end bearings changed every 800k as a pre-caution, so if you are doing heavy trackdays, this is obviously the first port of call...
But as a pure road bike, most F4's are pretty robust.
VELOCEMOTO HD The Art of Italian Sportbikes on film.
Velocemoto is offline
post #10 of 10 (permalink) Old 06-19-2010, 12:10 AM
Talking
squibby;
re oil changes....i lived in Heidelberg Germany and worked between Zürich and Lucerne at F.W. Egli in Switzerland.....
i had a BMW R75/5 with 2 quarts of oil in it.....i ran down the E-4 Autobahn at red line +300rpm, total trip 2 3/4 HOURS. i changed the oil at 500 miles, oil and filter at 1000 miles
did it for years....think track days are hard.....think from the BP station in Heidelberg to the Swiss border OVER red line the whole way
i sold it at 140,000 miles, no work ever done other than valve adjustments, straightening the push rods and torquing the heads
highest rpm observed 8,200, in 3 gears, witnessed by the pillion, Seppi Arnold, Egli's workshop boss....thats 1,000 OVER red line, yes it was a freak, lifted the front wheel in 3rd
yes, i change the oil at 2,000 on all my bikes.....simple, even number on the odometer.....change the oil
i have a '62 Abarth race car.....the difference between the stock oil system and a fully filtered one, is 1 race to a motor or 1 season!!!!
me, i'll change the oil more often......for peace of mind LOL
