Faring panel grille rubs on cooling pipe? - MVAgusta.net
post #1 of 6 (permalink) Old 06-14-2010, 05:17 PM Thread Starter
Tont's Avatar
Anyone with an F4R that suffers from the grille on the left fairing pannel rubbing on the coolant pipe. As you can see, its marked it quite badly. I note that the grille has a small section cut out of it (as viewed on inside face of the panel). I haven't made any mods so assume its factory standard.....or factory bodge! Is yours the same??
The wife said "Go buy some Art"...
...................__O
................_-\<,_\
...............(_)/ (_)
I bought art.....MV Art!
Tont is offline
post #2 of 6 (permalink) Old 06-14-2010, 05:39 PM
Mine doesn't do that. I am trying to remember if there is a rubber shield for the aluminum tube. I will look when I get home.
RobP is offline
post #3 of 6 (permalink) Old 06-14-2010, 07:19 PM
What happened to the rubber shield that is supposed to be on your aluminum tube?
Just kidding. The rubber shield is further forward.
Never seen something like that.
post #4 of 6 (permalink) Old 06-14-2010, 07:50 PM
I just looked at mine and there is about 1/8" clearance between the tube and the screen. I wonder if you have a bent tab mounting tab for the fairing or if the tube is on in such a way that it sticks out too far?
RobP is offline
post #5 of 6 (permalink) Old 06-15-2010, 08:42 AM Thread Starter
Tont's Avatar
makes me wonder if the dealer put everything back correctly when the last rad was replaced
Tont is offline
post #6 of 6 (permalink) Old 06-15-2010, 08:58 AM
F4RT's Avatar
same thing with mine..
F4RT is offline
