2008 F4 electrical issue - MVAgusta.net
post #1 of 7 (permalink) Old 06-13-2010, 08:23 PM Thread Starter
Mika's Avatar
My F4 has an electrical issue I can't seem to fix. While at the track the odometer and speedo stop working, the dash will then lose all power, and then bike will drop cylinders, and fail to restart. I thought it was a bad alternator, my mechanic took it out and tested at a local shop. They said it was good. My mechanic then thought it was a bad diode, which I'm told is the battery charge lead that comes w/the bike from the factory. So he disconnected it, and we thought it was fixed.
Then the same thing happens at the next track day. I went and bought a battery charger that has an alternator check function. The charger says everything is ok. But as it's setup for track only I cant really go for a good ride to truly test it.
any ideas on what to do before I resort to shipping the bike to an MV dlr? there are none close at all.
thanks
'08 F4R312
'06 Brutale 910
'06 Triumph Daytona 675 - track
'04 Ducati ST4s sold
'05 Ducati Monster S2R 800 sold
Mika is offline
post #2 of 7 (permalink) Old 06-13-2010, 08:42 PM
cruiser's Avatar
Hi Mika,
The 07 and prior Brutales occasionally had a glitch with the SPU (Service Power Unit), do a search on SPU and you'll find numerous threads on symptons.
If SPU, it can't be repaired, has to be replaced.
Tim
Current
MV Agusta Brutale 1090RR
Past
MV Agusta Brutale 750s
cruiser is offline
post #3 of 7 (permalink) Old 06-14-2010, 05:27 AM
He probably hates me for saying so, but I would send a PM to Hartley Hare. He doesn't post at all anymore, but he is an electrical god and has helped numerous members with electrical issues. If he can't sort it out, burn the bike and bury it.
post #4 of 7 (permalink) Old 06-14-2010, 06:10 PM Thread Starter
Mika's Avatar
Originally Posted by cruiser View Post
Hi Mika,
thanks but my question is about a 2008 F4, not a Brutale 2007 or prior.
I have also checked the 2 fuses on the left side of the frame by the alternator.
'08 F4R312
'06 Brutale 910
Mika is offline
post #5 of 7 (permalink) Old 06-14-2010, 06:20 PM
cruiser's Avatar
Hi Mika - yep, fully understood the question...it was only a suggestion given the nature of the problem you described. ...and if the SPU has gone, then the fuses will all look ok.
Best of luck
Tim
Current
Past
cruiser is offline
post #6 of 7 (permalink) Old 06-14-2010, 07:10 PM
number2's Avatar
Have you installed any electronics device on the bike recently. I put a pcIII on a bike and did not hook up the ground correctly and it and it caused a similar problem.
number2 is offline
post #7 of 7 (permalink) Old 06-15-2010, 10:20 PM Thread Starter
Mika's Avatar
I may have accidentally connected the factory installed battery charge lead backward. I assumed the shape would prevent a surge,etc. maybe i was wrong. I lost the cap to that lead - could that be an issue? my mechanic said he disconnected that lead when he thought he had it licked.
But no I have not installed any electronics on it. It has been w/o headlights, turnsignals, etc. since March 2009. The bike in my avatar.
5 track days since 4/09 and a handful of rides to my shop at ~20 miles from my house.
'08 F4R312
'06 Brutale 910
Mika is offline
