Neutral gear light not working! - MVAgusta.net
post #1 of 7 (permalink) Old 06-11-2010, 07:53 PM Thread Starter
Timster's Avatar
Any thoughts? Everything else seems to be working just fine. Lights, highbeam, turnsignals, speedo. I checked all fuses on the right side.
Any help is appreciated. Thanks.
__
MV F4 1000 S Red/Silver
HUSABERG FS 570
Timster is offline
post #2 of 7 (permalink) Old 06-11-2010, 11:45 PM
Talking
Timster;
to test the switch; on the right rear of the motor there is a single green /yellow wire with a bullet connector.....unplug it and connect an Ohm meter or test light, to the other wire, if memory serves me, its black, in neutral you should see continuity to ground or the test light should light if clipped to bat+
to test the bulb, key on, ground the green /yellow wire, the light on the dash should light up....
post #3 of 7 (permalink) Old 06-12-2010, 12:17 AM Thread Starter
Timster's Avatar
Timster;
to test the switch; on the right rear of the motor there is a single green /yellow wire with a bullet connector.....unplug it and connect an Ohm meter or test light, to the other wire, if memory seres me, its black, in neutral you should see continuity to ground or the test light should light if clipped to bat+
Thanks Noel. The thing is i can only start the bike with the cluch pulled even when it's in neutral. After the engine starts i just let go of the clutch and everything is fine. Does that makes sence?
__
HUSABERG FS 570
Timster is offline
post #4 of 7 (permalink) Old 06-12-2010, 12:33 AM
Wink
Tim;
sounds like the switch or the connection to it, somebody else had the same problem the other day......i went down and tested mine.....switch doesn't ground in neutral.....worked when i bought it, next time i tried it, it didn't LOL
post #5 of 7 (permalink) Old 06-12-2010, 05:38 PM
Banned
Notoriously fragile neut switch - take it out and clean it, it will probably work fine, for a while then clean it again.
mark m is offline
post #6 of 7 (permalink) Old 06-13-2010, 07:19 PM Thread Starter
Timster's Avatar
Thanks guys.
__
HUSABERG FS 570
Timster is offline
post #7 of 7 (permalink) Old 06-13-2010, 10:06 PM
svldvc's Avatar
so did you get it fixed?
Any updates??
~Serge~
svldvc is offline
