high speed compression - MVAgusta.net
post #1 of 9 (permalink) Old 06-09-2010, 01:26 PM Thread Starter
Baronvonbombburst's Avatar
I`ve got a f4 1000 shock in my f4 750. I`ve got the settings, but i seem to remember reading somewhere that the high speed compression adjuster is set differently from the low speed.
If , for example , the manual says to set the low speed comp to 12 click`s. I would wind the screw in clock-wise an then count 12 clicks back out.
Is the high speed the same ( all the way in clock-wise then count out, say 6 clicks )? Or do i turn the high speed adjuster all the way out ( anti-clockwise ) an then count 6 clicks clock-wise?
Any help is appreciated.
Baronvonbombburst is offline
post #2 of 9 (permalink) Old 06-09-2010, 01:37 PM
Low speed is FROM clockwise.
High speed is FROM counter clockwise.
post #3 of 9 (permalink) Old 06-09-2010, 01:38 PM
Turbo329's Avatar
Off the top of my head, the manual starts their adjustments from opposite ends of the adjustment range.
One starts at full soft (Anti clockwise to the stop) and the other starts at full stiff (Clockwise to the stop)
..you'll need to confirm which one by consulting your manual.
2005 MV F4-1000S
Turbo329 is offline
post #4 of 9 (permalink) Old 06-09-2010, 01:38 PM
Turbo329's Avatar
Man you type fast!
2005 MV F4-1000S
Turbo329 is offline
post #5 of 9 (permalink) Old 06-09-2010, 01:38 PM
You probably already know this, but high and low speed compression have nothing to do with how fast you're traveling.
post #6 of 9 (permalink) Old 06-09-2010, 01:39 PM
Originally Posted by Turbo329 View Post
Man you type fast!
Good group at LIghtning on the 19th and 20th of this month. Will we see you there?
post #7 of 9 (permalink) Old 06-09-2010, 01:46 PM Thread Starter
thanks for the quick reply`s.
post #8 of 9 (permalink) Old 06-09-2010, 01:47 PM
Turbo329's Avatar
I would like that but my wife was trippin' when I mentioned another track day. lol
Is it with Absolute?
I was scheming on Monticello North on 8/2 and 8/3 with TPM.
....maybe I can squeeze a Lightning in there. I like that track. I'll keep you posted. I gotta make up with the wife because she's still pouting for 2 days now.
2005 MV F4-1000S
Turbo329 is offline
post #9 of 9 (permalink) Old 06-09-2010, 01:48 PM
Turbo329's Avatar
No sweat!
2005 MV F4-1000S
Turbo329 is offline
