2010 F4's variable length intake system - MVAgusta.net
post #1 of 2 (permalink) Old 05-24-2010, 07:23 AM Thread Starter
F4dream's Avatar
Exclamation 2010 F4's variable length intake system
I heard from some reliable source the OEM Airfilter on the 2010 F4's doesnt fit properly so the plastic frame come loose and a lot of dirt comes inside the airbox.
It's so worse that the variable length intake system locks due to the dirt and doesn't work anymore!!!
Luca
F4dream is offline
post #2 of 2 (permalink) Old 05-24-2010, 11:30 AM
haupti's Avatar
Luca, this was discussed a few weeks ago extensively. The problem occurred on one of the first presentation bikes in England. As of my understanding was the air filter removed by several journo's and this multiple times. One of this knuckleheads didn't tightened a clip correctly and this caused the problem You heard of. I wouldn't worry and if You need to look at Your variable intakes make sure You fasten the clips of the Air Filter correctly. Other than that enjoy Your F4.
haupti is online now
