Havent got any further forward in resolving the fan problem. Have been reading some of the older posts on here and done further checks but I have reached the point on where to or what to do next. With the bike still in bits its beginning to look a bit sad.
Anyway someone on here could just possibly point me in the right direction instead of going round in ever decreasing circles........
I dont know if this has occurred since I ripped out the alarm system or just plain coincidence.
I checked out the relay and that is switching ok on the two vertical terminals with the centre terminal missing.
There is voltage 12v comming out of the connector plug on the yellow fused wire, the fat yellowish grey wire and 10.5 v out of the white/black stripe thin wire which I assume goes to the ecu.....no voltage present on this wire when the button is pressed in to prevent starting mode. The grey central wire has no voltage which I assume goes to the fans and also to the temp sender unit
I have tested the fans with a direct feed from the battery and all ok
According to the shop manual removing the temp sensor plug [in rad sensor] and bridging the wires the fans should work. No they dont!!
There is voltage from the plug wire blueishgreen color of about 4.75v which I assume is ok.
Big question.....to substitute the relay in case there is fault between the other terminals, how do I wire the connectors to test the fan operation??? as if the relay was fitted.
Come on fellas, the good weathers here and its getting frustrating
