custom rearset - MVAgusta.net
post #1 of 19 (permalink) Old 05-20-2010, 03:42 PM Thread Starter
F4RT's Avatar
custom rearset
iam bored with the stock rearset so i decided to design my own one.as soon as the plans are ready, i'll cnc it from alloy. the eccenter that will hold the footpeg(folding rizoma or lsl-not sure..) will be powdercoated.
what do you think?
here are some sketches:
cheers
F4RT is offline
post #2 of 19 (permalink) Old 05-20-2010, 04:37 PM
I think they look nice but will cost you a small fortune to make. Your eccentric is a 4 axis piece at minimum or EDM. You would need to make and sell quite a few to make financial sense. You will probably run into issues with the gear shaped eccentric. And then you may have to fight a patent infringement claim if you intend to sell them.
RobP is offline
post #3 of 19 (permalink) Old 05-20-2010, 04:57 PM
The Machinist
B.Harris's Avatar
You could wire EDM the eccentric, but that's time consuming and expensive. 4 axis is definitely the best way. Actually I think the eccentric is the most time consuming and difficult piece to make. The rearset itself looks strait forward enough to machine. You might want to consider using stock screw locations for the heal plates to help with cost also. The chamfer around the main body itself is nice looking but you need a little more of the flat surface area around the 2 main mounting holes because the chamfer encroaches on the holes creating a knife edge. This isn't ideal for machining, or boots and shoes being located right next to them for obvious reasons. With that being said I do like them quite a bit and think your renderings are pretty nice.
B.Harris is offline
post #4 of 19 (permalink) Old 05-20-2010, 05:03 PM
The Machinist
B.Harris's Avatar
You might want to put an eccentric inside the large eccentric to offer optimal adjustability.
I really like the Ti/red color scheme.
B.Harris is offline
post #5 of 19 (permalink) Old 05-20-2010, 05:07 PM Thread Starter
F4RT's Avatar
this is gonna be a one-piece-edition, i dont intend to mass-produce it. by accident, ive access to a 5-axis cnc.waterjet will do the eccentric nicely..
F4RT is offline
post #6 of 19 (permalink) Old 05-20-2010, 05:12 PM Thread Starter
F4RT's Avatar
double eccentric makes sense!thnx
F4RT is offline
post #7 of 19 (permalink) Old 05-20-2010, 05:25 PM
The Machinist
B.Harris's Avatar
Waterjet tolerances may be a bit loose for that type of fit. If you have access to a 5-axis go that route, you'll be better off.
B.Harris is offline
post #8 of 19 (permalink) Old 05-20-2010, 08:30 PM
number2's Avatar
before you go to all that trouble check out acculign rearsets.
number2 is online now
post #9 of 19 (permalink) Old 05-20-2010, 08:55 PM
Cash_Dawg's Avatar
Nice design.. The red/ti and black/gold look great.
As others have mentioned the double eccentric would allow for most adjustability.
let us know how you go with it all.
_________________
A closed mouth gathers no feet.........
Cash_Dawg is offline
post #10 of 19 (permalink) Old 05-20-2010, 10:25 PM
JS Agusta's Avatar
Nice ,they remind me a little of these.
2014 B3 ITALIA
2010 Aprilia Tuono sold
08 Ducati 1098S
06 Ducati 999S sold
Bimota Santa Monica
2004 R1150RS
2005 MV F4 BLUE & Silver Sold
2010 Aprillia RSV4 R White:sold
1978 BMW R100RS sold
2008 Ducati SC 1000 S Sold
JS Agusta is offline
