Well nut Again - MVAgusta.net
post #1 of 12 (permalink) Old 05-17-2010, 07:24 PM Thread Starter
lee
lee's Avatar
Well nut Again
Had an interesting email today from a member who broke a well nut in the airbox. Took it all apart and saw the piece sitting on an intake valve. He got it by putting some bubble gum on a wire and fishing it out. Pretty creative if you ask me, and I'm going to remember that one.
lee is offline
post #2 of 12 (permalink) Old 05-17-2010, 09:16 PM
DAVE M's Avatar
That Sure Saved Him Alot Of Money !!!
DAVE M is offline
post #3 of 12 (permalink) Old 05-17-2010, 09:36 PM
Sagerider's Avatar
What can be done to prevent that from happening?
If Adam and Eve were Chinese, we would still be in paradise
because they would have ignored the apple and eaten the snake!
Sagerider is offline
post #4 of 12 (permalink) Old 05-18-2010, 12:16 AM
Not very lucky..
Darkside's Avatar
Replace them every time you remove it like the manual says. They're pretty cheap anyways.....
Darkside is offline
post #5 of 12 (permalink) Old 05-18-2010, 01:39 AM
Obviously it's the pair of well nuts to the engine side of the air filter that are the critical ones but as Darkside says, just replace them everytime you have the injector covers off. Also make sure you have the screw positively engaged with the threaded insert within the rubber well nut. If it doesn't screw into the insert properly, i.e you have it slightly cross-threaded, the insert can drop off on the inside.
Keep one wheel down!
No MV's in the garage anymore
john is offline
post #6 of 12 (permalink) Old 05-18-2010, 10:27 AM
Well, taking away his bubble gum woud be a start! Just kidding. I love "blue collar" creativity
mrossk is offline
post #7 of 12 (permalink) Old 05-18-2010, 01:36 PM
or eliminate the damn POS and put a Rivnut in there;
http://www.cardinalcomponents.com/fasteners.htm
notice how long the product has been around?
~75 years!!!
post #8 of 12 (permalink) Old 05-18-2010, 01:37 PM
style_one's Avatar
situations like that is why i bought a telescoping magnet. but gum IS cheaper...
style_one is offline
post #9 of 12 (permalink) Old 05-18-2010, 01:46 PM
a magnet won't work here...... its brass and rubber
post #10 of 12 (permalink) Old 05-18-2010, 05:30 PM
Nicolino's Avatar
I have described a perfect solution to this problem before so here it is again ; Get yourself new wellnuts and a longer bolt 3/4 of an inch or 1inch long , insert the longer screws thourght carbon or plastec part first , Screw both longer bolts with wellnuts first (just start the thread ) then put some vaseline or something like dishwashing liquid on the rubber so it will slip into the hole lot easier . Pusth both willnuts in and tighten , You 're done, without a worry that you are going to drop anything inside.
Nicolino is offline
