exhaust mod-lambada sensor - info please - MVAgusta.net
post #1 of 4 (permalink) Old 01-27-2010, 01:24 PM Thread Starter
chay250's Avatar
i know this subject has been covered on this forum but i can not find the answer i am looking for so can you guys answer the following questions.
i have removed the exhaust on my 312r (headers&link pipe all one)and would like to remove the catalyst
1 do i plug the lambada sensor back in or leave it unplugged
2 will the bike run ok
3 do i req a differant eprom
i don't want to go ahead with the mod and cause myself a shit load of problems
thanks colin
chay250 is offline
post #2 of 4 (permalink) Old 01-27-2010, 02:22 PM
You need to put back the Lambda sensor & install race EPROM on the 312R.
Otherwice the engine will not run properly & not having all the extra power.
Remember that Powercomander only changes the fuel injection, not the ignition.
Please read the "Baffle Modification" thread for more info.
Best Regards,
312R Corse
SWEDEN
sigmond is offline
post #3 of 4 (permalink) Old 01-28-2010, 04:50 AM
postman_bat's Avatar
yep lamabda has to be refitted
postman_bat is offline
post #4 of 4 (permalink) Old 01-28-2010, 05:49 AM
X81
thanks colin
If you remove the lambda then the std ecu will eventually log a fault and run without it. Long term this will make the lower rpm even worse than it already is.
To get round it you will need what is called a "race" ECU that will switch the lambda off. This then means that you can fit a PCIII to remap the fuelling which will go some way to helping things out but the bike will still have a number of issues with poor running below 5krpm.
There is another cure availabel from me in the shape of a fully programmable ECU that will properly fix all low rpm issues and boost all round performance everywhere.
Please don't take my (biased) words for it, do a search for Microtec or Microtek etc. I hope you will find all the information that you need.
X81 is offline
