Electrical Gremlins!!!! - MVAgusta.net
post #1 of 13 (permalink) Old 01-20-2010, 02:20 PM Thread Starter
I have an unusual problem relating to the electrics.
If I wash down the bike - the indicators and dash lights flicker and go on and off - not unusual i hear you say but I can also remove the ignition key and still start the bike up with the key removed!!!
It only happens when the bike has been washed. I have sprayed the man suspect areas with plenty of wd40 - ignition barrel all electrics on the clip ons and anywhere i believe water may penetrate but without success!!
I'm wondering if there is an earth problem or wiring loom connection problem but don't know where to begin!!
Any help would be appreciated
paul123kenneth is offline
post #2 of 13 (permalink) Old 01-20-2010, 04:52 PM
MihaSLO's Avatar
The problem is in washing the bike. MVs are pretty sensitive on the electronic part of motorcycle. The water gets in the relays and the problems start.
MihaSLO is offline
post #3 of 13 (permalink) Old 01-20-2010, 05:29 PM
fazer6's Avatar
There's lot's of places in the loom and CDI (aka SPU) and switchgear MV's are not well waterproofed.
Stop washing your bike with water.
fazer6 is offline
post #4 of 13 (permalink) Old 01-20-2010, 06:09 PM
I ride my bike in VERY heavy rain and havent had a single problem yet... HHHMMMMMM MIght go about trying to waterproof stuff.
extremachn1 is offline
post #5 of 13 (permalink) Old 01-20-2010, 06:34 PM
MihaSLO's Avatar
Riding is not a problem, had done it myself in heavy rain, because got catched. But washing is a no-no.
MihaSLO is offline
post #6 of 13 (permalink) Old 01-20-2010, 10:55 PM
rainy day project...
get a tube of dielectric grease.....put some on EVERY electrical contact.....
i live 400 meters from the Pacific Ocean.....EVERYTHING corrodes here, now add electricity....
post #7 of 13 (permalink) Old 01-21-2010, 05:34 AM
I was told on a few occasions never to wash the MV's with a hose etc.... as water finds its way in to areas that water shouldn't be in.
Cash_Dawg is offline
post #8 of 13 (permalink) Old 01-21-2010, 05:57 AM
I use a hose all the time, and i belive i have washed my bike 50 times this summer No problems, at all. Never use a strong beam of water, and never ever use high pressure water.
Belloq is offline
post #9 of 13 (permalink) Old 01-21-2010, 07:17 AM
Ditto. I do the same after every single ride. I use a light spray setting on the hose & never directly on the instrument panel. I then chamiose it dry and take for a quick blast around the neighbourhood to ensure that the water beads I can't reach are vapourised before I put her away. I then tell her how much I love her & if I was a boy bke, the things that I would do to her....errrrr I digress.
I have no problems either Maybe the pressure, how long water is thrown onto it & where might be something that is relevant.
MVista is offline
post #10 of 13 (permalink) Old 01-21-2010, 10:33 AM
Isn't there a low spot in the wiring loom that collect water and causes corrosion or shorts on some of the F4s??? Seems I have read this somewhere here. A problem with some connectors that corrode at that spot, addressed on later model bikes??
I wash my bike with a garden hose, blow dry with compressed air...have been caught out and ridden in the rain...no problems. The bikes have to be somewhat water proof or our friends in the UK would never get to ride !!!!
