Running rough / on 3 cylinders? - MVAgusta.net
post #1 of 11 (permalink) Old 01-19-2010, 03:02 AM Thread Starter
Hi All,
Having only had my MV for 2 weeks and after 2 year absense, there is one thing troubling me about the F4 1000S, though I'm not sure whether its normal or not.
I find that for the majority of the time its very stuttery at low speeds, and this morning cruising over the Anzac bridge there was a noticable change in engine note followed by what seems to be less power and response...
On the way back home it was smooth for the start of the trip, feeling much more resposive and pulling wheel up slightly in second without trying, but once again started to become stuttery at low speed and not very responsive, and I dont think it would have been so eager to lift the front wheel.
I dont see much difference at idle, but I'm just not familiar with the bike as yet.
Given that I've only ridden the bike a couple of times it concerns me and I'm thinking about taking it back to the dealership asap.
So far I've not really given the bike due to not riding for 2 years and I'm finding my riding legs again, plus two trips have had the missus on the back which means controlled speed. Hell I dont think its been above 10k rpm in my hands yet.
Am I'm just being paranoid, or is the stuttering and response issues for what is a high performance machine?
Is there anyway to reset the ECU or something? It has RG3 pipes, but I'm not sure if it has a matching EPROM.
Any feedback would be great.
Simon
siwren is offline
post #2 of 11 (permalink) Old 01-19-2010, 03:09 AM
gazman's Avatar
How many K's has the 1000S done?
It could be the relay up under the left front of the fairing, it's attached to the frame just behind the radiator??
Mine went and I had to position it out side of the fairing ...as it would run rough when it warmed up!
gazman is offline
post #3 of 11 (permalink) Old 01-19-2010, 03:36 AM Thread Starter
Thanks for replying Gazman, its just ticked over 7000km.
When you mention the relay, did yours fail and you replaced it, it you just relocated the original?
I'm assuming this is a fairing off affair?
New to the MV world.
So far its awesome
siwren is offline
post #4 of 11 (permalink) Old 01-19-2010, 05:45 AM Thread Starter
I went and removed the left fairing, but is the relay you're refering to the little black unit about the size of a matchbox? It has MONT BY or similar on it?
If so, where did you move it too and what does it do?
I've also discovered that there is a coolant leak from the top radiator hose.
Definately going back to get that fixed.
Anyone got anything else that think cold be causing me trouble apart from the relay?
Simon
So far its awesome
siwren is offline
post #5 of 11 (permalink) Old 01-19-2010, 06:00 AM
minime's Avatar
Sounds like the EBS relay slowly going dead on you. When the relay heats up it would start playing up - ie feels like it is running on 3 cylinders. Do a search on my name there should be a part number somewhere.
minime is offline
post #6 of 11 (permalink) Old 01-19-2010, 07:03 AM Thread Starter
Yeah I found out about the EBS relay by typing in "black matchbox" search and following the threads.
Ive since relocated it and will hit up the dealer for a new one.
Given that its been like this from the start and I just didnt know, I cant wait until tomorrow... should be awesome!
Thanks all for your help, hopefully it runs better tomorrow.
Simon
So far its awesome
siwren is offline
post #7 of 11 (permalink) Old 01-19-2010, 07:04 AM
It sounds like your EBS relay, as stated. They are about $110 new from the dealer. Or maybe one of our sponsors have them in stock. Try them first.
post #8 of 11 (permalink) Old 01-19-2010, 10:57 AM
hes
Mine did it too some time ago. I had the dealer replace the EBS relay and it did it again. I think after the third time now it is running well (third time they relocated the box away from the heat).
hes is offline
post #9 of 11 (permalink) Old 01-19-2010, 05:13 PM
gazman's Avatar
By juggling the wires, I could ride with it sitting outside of the fairing and never had any more trouble and then I went and sold the bike the same day I ordered a new one from the guy selling me the new bike!!!
Wasted about 150au dollars but the guy who bought my 1000S would have benefited!!!
Hopefully it is your problem also!!
gazman is offline
post #10 of 11 (permalink) Old 01-20-2010, 05:07 AM Thread Starter
I moved the unit as far back as I could, and it seems that it now takes longer to reach the point where the rough running, like before maybe 5 minutes, now its 10. So I'm assuming that the guts of it are cooked and that it'll have to be replaced.
After speaking to the dealer it seems that they were expecting it... Maybe past experiences
So far its awesome
siwren is offline
