A123 Battery instead or acid battery - MVAgusta.net
post #1 of 7 (permalink) Old 01-17-2010, 07:05 PM Thread Starter
Hi Guys,
I am new to the forum as I just got a red 08 R312 yesterday.
Today, after carrying the back from AZ learned the battery was dead. No big deal, I jumped start it the beast and that was it. However, I remember having this same issue with another motorcycle I owned years back and it is quite a paint in the neck.
So, I know of this special type of batteries called A123. They are the type of batteries that go inside some high end hybrid cars. The beautiful thing about these batteries is that once charged, they will hold the charge without dropping a tenth of a volt for up to 10 years!!! I have personally used the batteries in model airplanes and I must say they are amazing.
I think the issue with using these type of batteries lies on the alternator and the type of charge it will do to the battery. Has any of you try to retrofit these type of batteries in an MV Agusta before? And if so, what have the results been?
Thanks much
Mario
F4 1000R 312
MARIOS is offline
post #2 of 7 (permalink) Old 01-18-2010, 10:09 AM
Here is an article i found on the A123 batteries.
http://www.evworld.com/article.cfm?storyid=979
Seems the E powered model airplane guys are into this technology as it has a higher power output then the normal Lithium Ion batteries.
Looks like you will have to build your own battery pack for the bike, and the charging system will likely be problematic.
post #3 of 7 (permalink) Old 01-18-2010, 11:22 AM
redduck1's Avatar
buy a yuasha ytz10s, install it and be done. don't have to worry about problematic charging system or any alterations needed.
redduck1 is offline
post #4 of 7 (permalink) Old 01-18-2010, 03:23 PM Thread Starter
I found this motorcycle racing company in Germany that swears by this batteries....
http://shop.durbahn.de/shop/en/products/Batteries_superlight_!/_A123_LiFePower-Durbahn
I found a source for individual cells and purchased sixteen cells to make a 13.2 volt/ 9,200 mah battery pack. If you ever need the battery charger, it is actually a lot cheaper than other chargers out there ($ 40).
Since I am used to working with battery packs and carbon fiber this is not big deal for me. I will report on the results in a few weeks.
F4 1000R 312
MARIOS is offline
post #5 of 7 (permalink) Old 01-18-2010, 11:26 PM
hes
Do whatever you want, but make sure you have it charged and ready by the time I go visit you in Feb. No excuses !!!
hes is offline
post #6 of 7 (permalink) Old 01-18-2010, 11:47 PM Thread Starter
actually, I am going to test the battery in your KTM, if the electronics don't blow up, I will install it in the MV.
BTW, I installed a finger print reader in the MV. It only starts with my thumbs!!!!
It is freezing here at 57 degrees!!
F4 1000R 312
MARIOS is offline
post #7 of 7 (permalink) Old 01-19-2010, 11:00 AM
hes
Now I am going to have to cut your thumb off ....
hes is offline
