312R IssUes HELP .... WTF? - MVAgusta.net
post #1 of 39 (permalink) Old 01-13-2010, 03:55 AM Thread Starter
Snake_EYES's Avatar
First off I am tired, and stairing at the old LCD here like a zombie, had a long week so forgive me for being needy and zombified.
So finaly got myself and bike to Hawaii and after riding around my bike has the following issues:
1.) Perpetual hissing from has tank, like to much pressure inside?!
After I turn her off she starts to hiss at me! Bad girl!
2.) Chain on the bottom side of the sprocket seems a bit loose for my liking, is this normal? its tight on top, but I think it needs adjusment(yes I did search for this one and found 2 euroneous posts) can someone point me to a link>?
3.) Temps...wow, I bought the metal fans to replace the plastic RAD fans, have not done it. Anyone live in a warmer climate? I can attest to seeing 240 degrees in traffic...which results in me turning off the bike at lights, which keeps temps significantly down. I am going to do a CAT delete, is this a bolt on procedure? or do you have to replace the heads as well?
TIA, MV for life!
May you live as long as you want, but not want as long as you live
Snake_EYES is offline
post #2 of 39 (permalink) Old 01-13-2010, 04:11 AM
Totale's Avatar
Important one first is that hissing pressure or is it actually sucking in under vacuum? Try opening filler when you hear it. Probably blocked vent and there is a danger of collapsing your tank
Totale is offline
post #3 of 39 (permalink) Old 01-13-2010, 04:27 AM Thread Starter
Snake_EYES's Avatar
will do and will do....what about 2) and 3) ??
and nice to see someone is awake this late...lol....er wait, where is the land of the black?
post #4 of 39 (permalink) Old 01-13-2010, 04:35 AM Thread Starter
Snake_EYES's Avatar
ahhh, thanks for the PM's mate!
post #5 of 39 (permalink) Old 01-13-2010, 07:02 AM
2) If you look closely at the plastic chain guard on the bottom of the swing arm you will see a diagram on how much slack to run in your chain. Iirc, it is 6mm up and 6mm down from the midpoint. Or, to put it another way, push up on the chain and you should have 11mm of movement. (I think those numbers are correct.) Run the chain looser rather than tighter. You won't jump a tooth if it is a little loose, but if it is a little tight, you run the risk of premature wear on the rear hub bearings.
3) The mid pipe is a bolt on procedure. You do not need to change the headers.
Make sure the cooling system is properly bled. It is very likely you have air trapped in it somewhere.
post #6 of 39 (permalink) Old 01-13-2010, 07:19 AM
RT1
RT1's Avatar
ummm not on the 312r, needs new headers
best way to remove the cat is to take it to a exhaust place and someone who is good with a tig, and get them to remove the internals of the cat........quite simple and cheap
I live in Perth western australia and it get bloody hot here! I haven't had it over heat since doing these mods, even when its 35 degrees!!
new HO waterpump
engine ice
remove cat
muzzy fans
I also have a race ecu and rg3's fitted
= no more overheating ever!
good luck
RT1 is offline
post #7 of 39 (permalink) Old 01-13-2010, 07:33 AM
wa2fst's Avatar
The mid pipe is easy if you go that way to remove your cat. If you buy the ARROW decat it comes with new headers.
And Like CAG said you check the chain from the bottom not the top so 1/2" up is perfect fit.
No Idea about the tank but solutions above sound right
wa2fst is offline
post #8 of 39 (permalink) Old 01-13-2010, 08:10 AM
Go back and get a 750...no overheating issues there....
b42day is offline
post #9 of 39 (permalink) Old 01-13-2010, 08:24 AM
Totale's Avatar
As CAG said "Make sure the cooling system is properly bled. " not a easy as you'd expect - read a couple of good threads on here - try a search on "bleed"
Originally Posted by CAG - "There is a procedure to bleed the system. There are a couple of places for air to get trapped in the system. With out going too crazy i.e. lifting the front end and laying the bike waaaay over on its side, here is what you can do.
Remove the cap on the overflow bottle. start the engine and let it warm up. You want it to get hot enough that the thermostat opens and allows the coolant to circulate. Shut the bike off and let it cool. The coolant in the overflow bottle should have dropped about 1/4-1/2 a cup. Fill it back to the bottom of the sight area (the frame tube is a good reference point) and put the cap back on."
PS Land of the Black Prince is Wales UK
Totale is offline
post #10 of 39 (permalink) Old 01-13-2010, 10:52 AM
lee
lee's Avatar
Re the hissing. There are two "umbrella" valves made of very soft silicone in the tank cap itself. One is to relieve vacuum and the other to relieve pressure. Due to the design of the cap and it's passages they are rather slow to react and you will hear the hissing as the the pressure/vacuum slowly bleeds in/out. Sometimes they will squeal rather than hiss. Sings to you. It is my feeling that if you hear the sound then the valves are doing their job. It's when you don't hear it that you need to be concerned. A simple check is to open the cap and then close it. You should hear nothing at that point. Then wait a bit and if it starts up again then personally I wouldn't worry. I believe it's pressure in the tank from engine heat that you hear.
lee is offline
