Speedo - MVAgusta.net
post #1 of 4 (permalink) Old 01-03-2010, 12:16 AM Thread Starter
MRT
MRT's Avatar
Speedo
Went for a ride this morning and after I stopped for a drink my speedo died. It was working fine when I parked it but when I restarted it the speedo just reads zero. I checked plugs and that but they seem okay. Tacho and warning lights are all okay. Any one had this problem? I did a brief search but couldn't see anything about it.
thanks
Mat
MRT is offline
post #2 of 4 (permalink) Old 01-03-2010, 12:55 AM
SteveGT's Avatar
My handbook says if your speedo does not work, check your fuses - but not which fuse!. Is everything else working like your horn and lights?
Plan #2 would be to check the speedo sensor located next to the water pump on the LHS.
Nil desperandum bastardo carburundum !!
SteveGT is offline
post #3 of 4 (permalink) Old 01-03-2010, 12:55 AM
You mean the speedometer is not recording speed?....look at the connection from the speed sensor to the wire harness... then at the bolt holding the reluctor onto the output shaft...finally the sensor itself.
post #4 of 4 (permalink) Old 01-03-2010, 12:57 AM Thread Starter
MRT
MRT's Avatar
Yeah mate everything else is fine, I will go and pull the fuses and see how we go. Thanks
MRT is offline
