Battery. . . - MVAgusta.net
post #1 of 13 (permalink) Old 12-30-2009, 02:57 PM Thread Starter
JChinch's Avatar
Battery. . .
Hey guys, sorry to do this (surely repeating a thread topic). I tried searching though older posts, but I didn't really find much. I can attribute that to my lack of forum activity.
Anyway, my battery is bone dead. I've been searching around and all I see are fairly generic batteries, this is what I'm wondering:
What have you guys used in the past?
If you were upgrading, what would you upgrade to?
Thanks guys, I really appreciate any help thrown my way!
James
99 4.6 HSE | 99 BMW M3 | 84 Alfa Romeo GTV6 | 02 MV Agusta F4 | 78 MG Midget | 79 Series III 109 |
"Initial Success or Total Faliure"
JChinch is offline
post #2 of 13 (permalink) Old 12-30-2009, 03:09 PM
demitris's Avatar
In my opinion, any battery from a reputable company is ok. I found that the YTZ10S works best with my 2 f4's and my Brutale.
...People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs...
demitris is offline
post #3 of 13 (permalink) Old 12-30-2009, 03:17 PM
cooper3309's Avatar
The YTZ10S from YUSA or Interstate
01 750S W/1000R engine
01 Ducati 748 W/853 kit
03 Yamaha R1 (SOLD)
01 Kawasaki KX 125
88 Yamaha YSR 50
01 Yamaha R6
03 Suzuki DRZ pitbike
1982 Honda 110 atc
Yamaha PW50
1978 Honda 90 atc
2011 Yamaha Grizzly 700
2008 Yamaha Raptor 660
1975 Kawasaki G5 100
cooper3309 is offline
post #4 of 13 (permalink) Old 12-30-2009, 04:09 PM
Nicolino's Avatar
I recomend to stay with Yuasa , just recently discovered a small batery leak ( a drip ) down on my suspension and about a nickel size mark on my swingarm (oh crap) , luckily I have cought it early so dammage is not so bad except that mark on the swingarm. A wirebrush and a little bit of flat black paint touch up can fix it. Anyways I got rid of the batery so cant tell you what brand it was but I remember that it was not a Yuasa and it was made in china ??? I keep hiting myself over the head for buying cheaper batery , No more !!! Acid on alluminum parts - not good , get it ??? So folks don't be cheap and buy the best you can !!! Your MV is worth it .
Nicolino is offline
post #5 of 13 (permalink) Old 12-30-2009, 04:14 PM Thread Starter
JChinch's Avatar
Thanks Guys,
I had a BTZ12S in there... to be honest, not exactly sure what that means, I'll have to look up the cranking amps and such. . .
Thanks for the quick answers though!
James
EDIT: Just looked up what I had in there, all I see are vented, which mine was not. . . It was a sealed battery. Just to clarify.
JChinch is offline
post #6 of 13 (permalink) Old 12-30-2009, 08:27 PM
bogie1072's Avatar
Check motowheels speedcell battery. It is a good battery
Will not leak, slow discharge, will save you 5-6lbs. Cheapest
weight reduction possible besides diet or a huge growler
bogie1072 is offline
post #7 of 13 (permalink) Old 12-31-2009, 08:20 AM
MY YUASA LEAKED!!!!! only 8 month old.
It made a right mess of my swinger & suspension linkage, & it took some sorting.
I now buy a cheaper battery & replace it every biking season for peace of mind. Well worth £35.00.
I think the main reason for leaking is the vibes & laying on its side. When I put mine in now I line the tray with a bit of polythene sheet to catch any possible leaks.
bungle is offline
post #8 of 13 (permalink) Old 12-31-2009, 09:17 AM
Nicolino's Avatar
Well, so there you go,everytime you try to advise someone, someone steps in to contradict your advice,so I withdraw from this discussion . I ques any product can fail !!!
Nicolino is offline
post #9 of 13 (permalink) Old 12-31-2009, 10:07 AM Thread Starter
JChinch's Avatar
Bungle, was it not a sealed battery? (silly question I know)
JChinch is offline
post #10 of 13 (permalink) Old 12-31-2009, 10:39 AM
If your Yuasa leaked then it was not properly prepared for service.
Either the wrong quantity of acid was used, or the battery was not initialized with the correct type of charger.
The AGM batteries we use now have NO loose acid inside the casing when properly serviced. All fluid is absorbed into the glass mats (AGM) and remains there.
The venting system is a labyrinth primarily designed to keep the hydrogen gasses contained while allowing internal heating and cooling pressure changes relieved.
