Superbike radiator for the F4 - MVAgusta.net
post #1 of 28 (permalink) Old 12-29-2009, 07:42 PM Thread Starter
The_castle's Avatar
Another thread from our slow progress department.
This used radiator was sourced from Germany. It has no fan(s) and is used on race bikes. I intend to mount it to my 312R after some brackets for fans have been welded on.
Interesing that the radiator had a pressure cap on the upper right hand corner. This was about 15 mm too tall and hit the RHS air duct. It seems that MV designed some different air ducts for the F4 superbike that allowed this radiator to fit but it simply won't go on to the standard setup. The pressure cap has been removed and a 6 mm thick block of aluminium was welded in place then a hole was drilled & tapped to accept the brass fitting seen in the close up picture.
I'll drop the radiator off this afternoon at a local shop to have the brackets installed. It sould be un the bike early in the new year.
The_castle is offline
post #2 of 28 (permalink) Old 12-29-2009, 09:37 PM
sbk radiator
The_castle;
i would have modified the air duct, then you use the header tank as a non-pressurized over flow tank....
think how many possible leak spots you eliminate that way
are there any manufacturer names or part numbers on it?
i want one!
post #3 of 28 (permalink) Old 12-29-2009, 10:28 PM Thread Starter
The_castle's Avatar
It's by Taleo Tecnoracing in Italy.
Right here: http://www.taleotecnoracing.com/
It's a pretty basic website. No price on them but they may still be available.
I did think about altering the intake duct for about .5 of a second. They are MV Corse carbon. I believe in Karma and that's just asking for trouble.
OPP Racing offer a similar system. I will send you a link via PM.
Dave.
post #4 of 28 (permalink) Old 12-30-2009, 01:14 AM
thank you Dave, for the links
post #5 of 28 (permalink) Old 12-31-2009, 12:18 PM
ODJEBI68's Avatar
Is this like the one MotoCorse used to sell for over 5000.00?
ODJEBI68 is offline
post #6 of 28 (permalink) Old 12-31-2009, 01:40 PM Thread Starter
The_castle's Avatar
Good question, I paid 480 Euro which is about $1,050 New Zealand dollars which is about $720 US dollars and that included shipping from Germany. To put that in perspective I'm told that just the top radiator for an F4 in New Zealand retails for $2,000 NZD. And mine, like many others around the world, sprung a leak a while back.
post #7 of 28 (permalink) Old 01-01-2010, 02:25 AM
adamv1000's Avatar
why not just isolate the top part of the radiator?. worked on mine no leaks at all and cost me 70$ AUD.
Unless you wanted it for the bling.
adamv1000 is offline
post #8 of 28 (permalink) Old 01-01-2010, 12:59 PM
new rad
adamv1000;
i want one because it increases radiator area, simplifies the cooling system and turns the header tank into a overflow tank, eliminating lots of potential leaks....pressurized joints
what's wrong with that?
post #9 of 28 (permalink) Old 01-01-2010, 01:55 PM Thread Starter
The_castle's Avatar
Bling & it's pretty light too. I'll run one fan.
post #10 of 28 (permalink) Old 01-01-2010, 10:41 PM
adamv1000's Avatar
adamv1000;
who was talking to you anyway? my question was to castle.
