@#%$^ ! Ruined my tail section by installing Clear Alternatives lights - MVAgusta.net
post #1 of 23 (permalink) Old 12-26-2009, 06:17 PM Thread Starter
yves's Avatar
Am livid !
Followed step by step instructions and still messed up big time.
Had the tail piece flipped over on a mattress in order not to damage it as I was fastening the CA light unit. Was kind of loose, so I had to tighten it a bit harder than the original set. The result can be noticed in attached pictures.
Do mind, I only noticed half an hour later when the tail unit was already back on the bike. It's not like anything cracked or so...went through it like butter.
Surely ruined my weekend. Dang.
Why on earth didn't Clear Alternatives call for some shims if fitting is an issue with these units ??????
On a different note - anybody knows where I can buy a tail unit for a 1078 ? (mine is a 312, but might as well get the nicer color scheme).
Yves
Fort Worth, TX
Bend, OR
2010 Ducati 1198R Corse LE
2008 MV F4 312R (RG3, X-Bikes ECU,...)
2005 Ducati 999S
2004 Ducati 998S Final Edition
yves is offline
post #2 of 23 (permalink) Old 12-26-2009, 06:32 PM
weld mva's Avatar
oh my god fitted one on mine and ended up with dimples was well fucked off got mine resprayed for £200.00
but yes clear alteratives should have warned us but this is easy after the event .
Take it to a body shop imsure they could sort it
merry xmas
weld mva is offline
post #3 of 23 (permalink) Old 12-26-2009, 07:49 PM
Manuel_F4's Avatar
Wow... looks horrible. sorry for that.
But I installed already three clear alternative taillights to my MVs (F41000S, F4750S and Brutale 910S) and no one damaged the tail section like that! So it is not clear for my, why this happened? Probably a little different between the MV tail sections?
Red cheers
Manuel
you should either accelerate or brake - never you should coast
Manuel_F4 is offline
post #4 of 23 (permalink) Old 12-26-2009, 07:56 PM
nathancast's Avatar
Not to bad! look on the bright side extra grip for luggage.
She has nipples!!! TASTY
nathancast is offline
post #5 of 23 (permalink) Old 12-26-2009, 08:35 PM
wow, that sucks. PM CAG to see if he has any tail sections that match your bike.
deeguy is offline
post #6 of 23 (permalink) Old 12-26-2009, 09:04 PM
timpants's Avatar
damn that sucks!
If I remember right... packaged with my tail lights was a round piece of foam with adhesive on one side. That piece goes on top in the light unit and acts like a shim and holds the unit in place.
Did you get one of these in your kit?
timpants is offline
post #7 of 23 (permalink) Old 12-26-2009, 09:13 PM
fazer6's Avatar
This has been seen lots before...You're not the first. IIRC there are some shims you need to transfer from the old unit to the new.
Bummer dude.
B4 750S [sold]
B3 675R [waiting]
fazer6 is offline
post #8 of 23 (permalink) Old 12-26-2009, 09:20 PM
timpants's Avatar
Bummer dude.
I just checked my original, you are right, the shim came off the original light unit.
timpants is offline
post #9 of 23 (permalink) Old 12-27-2009, 03:02 AM
Greny's Avatar
Hope this helps mate
http://cgi.ebay.de/Heck-MV-Agusta-F4...item3efb3bdfda
or full carbon
http://cgi.ebay.de/MV-Agusta-F4-750-...item5d237a43d0
These guys that sell the full carbon , i mailed those some time back about the correct weight , and said they couldn,t tell me.
But they answered fast.
Greny is offline
post #10 of 23 (permalink) Old 12-27-2009, 03:18 AM
diego's Avatar
Hi Manuel,i guess you did use those you bought from me, they are not clear alternatives !
rgds
motodiego
diego is offline
