'maximum' tire pressure? - MVAgusta.net
post #1 of 20 (permalink) Old 12-16-2009, 06:29 PM Thread Starter
henry-a's Avatar
would anyone know what's the maximum pressure the tires can safely be set at? i want to set the pressure at a higher level so that the tires wouldn't flat-spot. i would also move it to a different spot every couple of weeks.
i have been lazy to get two (front and back) stands; space has been a problem as well.
thanks.
henry-a is offline
post #2 of 20 (permalink) Old 12-16-2009, 06:32 PM
The Dude
TokyoLunch's Avatar
shouldn't that number be on the sidewall of the tire? usually I see 42psi or so.
I'm interested to hear comments about needing to move the bike in order to avoid a 'flat spot'.... ? (i don't move mine much if i'm not riding, sometimes a couple months at a time.)
Tokyo, Japan
TokyoLunch is offline
post #3 of 20 (permalink) Old 12-16-2009, 07:08 PM Thread Starter
henry-a's Avatar
thanks, dude. i will check the sidewall (should have checked before asking). if you aren't riding for a couple of months, i am assuming you have a trickle charger for the battery?
other alternative to moving could be resting on pieces of soft stuff like carpet, i think.
thanks.
henry-a is offline
post #4 of 20 (permalink) Old 12-16-2009, 07:15 PM
lee
lee's Avatar
Wink
Flat spots aren't permanent. They'll thump their way out after awhile. Good way to check your suspension settings in the spring.
lee is offline
post #5 of 20 (permalink) Old 12-16-2009, 07:32 PM
The Dude
TokyoLunch's Avatar
thanks.
Yes, I have an Optimate for charging the MVs and lately a friends racing Ducati. Just move it around every week or so. My FJR seems to not care about how long it sits....never needed battery attention! (knock on wood)
Tokyo, Japan
post #6 of 20 (permalink) Old 12-16-2009, 07:36 PM
cdamb's Avatar
Just remember when you take the bike out because it will turn in like nothing with high tire pressure.
B750 and B1078 RR both gone now.
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."~Mark Twain
cdamb is offline
post #7 of 20 (permalink) Old 12-16-2009, 10:56 PM Thread Starter
henry-a's Avatar
agree! :-)
henry-a is offline
post #8 of 20 (permalink) Old 12-16-2009, 11:02 PM Thread Starter
henry-a's Avatar
no, i wouldn't forget to set the right pressure in spring. i am pretty about anal about these things!
henry-a is offline
post #9 of 20 (permalink) Old 12-17-2009, 12:26 AM
Banned
remember pressures rise and fall with temperatures
best advice would still be to buy front & rear stand, not too expensive and better than having bike sitting on the side stand
The Good, Bad, & Ugly is offline
post #10 of 20 (permalink) Old 12-20-2009, 01:41 AM Thread Starter
henry-a's Avatar
the bike is stored in a heated garage; so, there is no temperature variation. you are right; i do need to get front and rear stands!!
thanks.
henry-a is offline
