What's up with this? - MVAgusta.net
post #1 of 15 (permalink) Old 12-07-2009, 09:42 AM Thread Starter
Ahhgooosta's Avatar
Noticed this every time back from a ride now. Bike's a 2000 and the roads are not bad out here. Don't ride in the wet either. Usually left side only or more. Greasy kind of residue...
Everything under the fairing seems OK; oil leaking, radiator, etc. Could this be just road grime? Seems like a weird place to see it show up. Never had this happen in Chicago.
Just curious if other F4's experience this on the road or if it's an indication of something else.
Ahhgooosta is offline
post #2 of 15 (permalink) Old 12-07-2009, 11:25 AM
lee
lee's Avatar
That looks to me like an oil leak given the color. Obviously coming from up front and above the joint between the pan and fairing. I would take off the fairings, re check for visible leaks and start wiping with your finger up high on all surfaces working your way down until you get some oil on your finger and then try to trace it from there. Alternatively you can clean all surfaces as best you can, pack paper towels around any suspect areas, ride it and then look for oil on the towels to help you zero in on it.
Oil and water seeps are a bitch to find the source of as the stuff will creep around all over as a thin film.
lee is offline
post #3 of 15 (permalink) Old 12-07-2009, 11:43 AM
That is either a fuel leak from the fuel connections under the tank or a seeping oil filter seal.
Both of which i have had & have appeared in the same place.
bungle is offline
post #4 of 15 (permalink) Old 12-07-2009, 11:57 AM Thread Starter
Ahhgooosta's Avatar
Hmm. I just replaced the fuel fittings a few weeks ago...
...perhaps not tight enough.
post #5 of 15 (permalink) Old 12-07-2009, 12:06 PM
chay250's Avatar
try checking the sump bolts!! - i had a nasty leak coming from below the sidestand and peeing out and under the fairing - turned out i had a couple of loose sump bolts.
colin
chay250 is offline
post #6 of 15 (permalink) Old 12-07-2009, 12:15 PM
1fastf4's Avatar
I had the same thing on my bike. Turned out to be an oil leak from under the valve gasket cover. Good luck.
1fastf4 is offline
post #7 of 15 (permalink) Old 12-07-2009, 12:15 PM
TimMV's Avatar
It is definitley not road grime...if it were, it would be more scattered on the fairing lower, not a distinct leak coming from the fairing union.
TimMV is offline
post #8 of 15 (permalink) Old 12-07-2009, 12:36 PM
JDS
King of Bling
JDS's Avatar
Send a message via MSN to JDS
All the above, and also have a look at the water pump oil seal.
EMAIL :
JDS is offline
post #9 of 15 (permalink) Old 12-07-2009, 12:47 PM
wa2fst's Avatar
Well thank god I just read this!! its your water pump. if you look at the bottom of your water pump on the motor side there is a tiny weep hole and what has failed is your oil seal that goes around ur impellar shaft. I just got mine all sealed up this Saturday from the dealer in Chicago. I had nursed mine for a while and now snow is here resealed it. for the mechanical seal behind the impellar, the oil seal, the seal that goes around the whole thing that goes into the motor, and the seal between the 2 halves was $50USD. I have a breakdown picture I will post up that will show you.
wa2fst is offline
post #10 of 15 (permalink) Old 12-07-2009, 12:54 PM
wa2fst's Avatar
Here is the breakdown these are the seals you need. the dealer I was referred to them and they got them all in under a week.its Team MCC. They recommend you scuff polish the new shaft and that you get a new shaft because the ones you get in the bike and order get polished by the bearings and basically allow the seal to let oil pass through. So when they scuff them they say it makes a better bond with the seal and have never had one come back.
Parts I replaced were #'s 19,7, 8, 3(the failed one) if you are a do it yourselfer. Its way easy the shaft actually knocks out towards the motor not the impellar side. should kock both bearings and seal all at once then you would not have to change # 19 it was a pain to get out like it had bonded itself to the metal but after some scraping and heating up I got it all out.
wa2fst is offline
