Fuel Connectors F4 - MVAgusta.net
post #1 of 15 (permalink) Old 12-01-2009, 11:50 PM Thread Starter
Fuel Connectors F4
New to MV,s, is it common for the plastic quick release connectors to crack and drop fuel all over the Motor. Is there a factory directive in regard to this. This bike I have is plated 02 and a Senna with only 80klms on the clock. How many have burnt without the owners knowing why????
Peter Gardiner is offline
post #2 of 15 (permalink) Old 12-02-2009, 12:05 AM
The_castle's Avatar
Welcome Peter. May I suggest using the search function above. Use the keywords from your post and you should find what you're looking for.
In summary it is uncommon. Normally due to careless fuel tank removal. Metal replacements are available from sources such as ebay.com
The_castle is offline
post #3 of 15 (permalink) Old 12-02-2009, 12:18 AM Thread Starter
As tank never off previously, 80klms only and only Tank only removed due to noticeable fuel leakage. Found both lines held together by white zip tie, most likely factory. I believe lines hardening and the stress they place on the very thin wall of the fittings causes them to crack through in the thinnest section. The Gold Coast distributor has mentioned they have sold several and had new plastic items in stock, at a bargain price of $250 the pair. This made me realise they must be selling several to keep them on the shelf. I had asked in regards to a metal replacement, but he had no knowlege. Thanks for the heads up, i will now try and aquire a better quality set
post #4 of 15 (permalink) Old 12-02-2009, 12:22 AM
The_castle's Avatar
post #5 of 15 (permalink) Old 12-02-2009, 01:11 AM
SteveGT's Avatar
Welcome Peter - you should only require the male metal connectors. The female (which fit ito the tank and coloured black & white) don't normally give problems.
For your information, a few years ago my new Triumph Sprint had the plastic connectors fitted standard from the factory and one broke within 2 weeks of delivery.....
Nil desperandum bastardo carburundum !!
SteveGT is offline
post #6 of 15 (permalink) Old 12-02-2009, 01:58 AM
I'd change both (male and female) just to be on the safe side
Keep one wheel down!
No MV's in the garage anymore
But...Ö..a new one is currently rising from the ashes......watch this space!
john is offline
post #7 of 15 (permalink) Old 12-02-2009, 05:13 AM
Pfatty's Avatar
Hi Peter, and welcome.
Yeah, Paul Feeney want's an arm and half a leg for those, but you do get the fuel line as well! I ended up buying metal ones through fleabay for about $30 aus and then a few dollars for some new fuel line. Sorted.
Pfatty is offline
post #8 of 15 (permalink) Old 12-02-2009, 07:59 AM
Nope, you are wrong there....someone had the tank off, for whatever reason, and broke them. Could have happened during initial prep for delivery by the selling dealer.
post #9 of 15 (permalink) Old 12-02-2009, 11:13 AM
Correct. The factory uses black zip ties.
post #10 of 15 (permalink) Old 12-02-2009, 05:55 PM
smilo996's Avatar
They actual connectors are used by several manufacturers (Triumph, Ducati....). Usually if there is fuel leaking it is the little o ring in the connector. This is only if you have taken the tank off though. I saw a couple of bikes in a workshop and both had cable ties at the neck of the connector.
I have taken these connectors out on a Ducati about 40 times with no problem at all. They seem(ed) pretty sturdy. However I got a new one and the connector hose and o ring broke first time I took them out. No idea why.
If Ducati bought MV then Rossi could finish his career on a Ducati and then go to WSB on an MV. We Wish......
smilo996 is offline
