TPS reset? - MVAgusta.net
post #1 of 14 (permalink) Old 11-26-2009, 09:01 PM Thread Starter
TPS reset?
My nearest dealer is 2.5 hrs away, and they are going out of business. Arranging service is becoming challenging. Is it possible to reset my TPS at home? Pull the battery mabye? Would any other brand of dealer have the necessary equipment if I can't do it myself?
ducgsxr is offline
post #2 of 14 (permalink) Old 11-26-2009, 09:33 PM
Better talk to Lee. The king of the TPS.
post #3 of 14 (permalink) Old 11-26-2009, 10:23 PM
TPS reset is quick and easy but you need the vdsts software, it literaly takes a couple of minutes. I would contact any local area .net guys and see if anyone in your area has one. If you where in northern CA I would be happy to do it for you...
RobP is offline
post #4 of 14 (permalink) Old 11-26-2009, 10:54 PM
it can also be done with a voltmeter and by following the procedure in the FAQ. It's a bit of a finicky process, but totally do-able. An extra set of hands helps.
mrossk is offline
post #5 of 14 (permalink) Old 11-27-2009, 10:22 AM
Don't most Ducati dealers have the VDSTS program?
post #6 of 14 (permalink) Old 11-27-2009, 11:20 AM
lee
lee's Avatar
The procedure for setting the TPS is extremely well described in the MV Faq blog. All you need to find out is the angle on the TB plates for your particular ECU at idle and fully closed. On mine I have the 16m ECU which requires 150mv with the plates fully closed (slightly sticking in the throats and off the idle stop screw) and 335-355 mv at idle which will equate to 1100-1200 rpm which you set with the idle stop screw. The 150mv is the key number as the ECU references that for all other throttle positions in order to give the proper CO-A/F. You can set the idle reading wherever you want to get the rpm you like as long as the 150mv is set. If your ECU is other than a 16m then 150mv may not be correct and you'll have to get that number. Guys in here will know.
Read the blog (google mv faq and find it). It will tell you how to completely set up the TB's from balancing all four to setting the CO pot in the ECU. If you have that style ECU. All you need is a multimeter, an 8mm socket and a flat blade screwdriver. If you tweak the CO pot you'll need a CO meter or A/F ratio gauge. And the guts to go in there and mess with it, which is the hardest part. No, hold that. The hardest part is disassembling the whole friggin' bike to get at the adjustments other than the TPS. It's just sitting there waiting for you on the right side of the TB's.
I've put some posts in the perf section about my excursion into this territory if you want to read them.
I am not the "king" of tps. Just an anal idiot. There are others on here who deserve that title way more than I.
lee is offline
post #7 of 14 (permalink) Old 11-27-2009, 03:02 PM
mikef4uk's Avatar
Lee, there is no setting procedure for a 1000R TPS except through the software, the potentiometer does'nt even have any slots to set it with on anything with the later ecu, sorry, it's the vdsts or nothing
mikef4uk is offline
post #8 of 14 (permalink) Old 11-27-2009, 03:21 PM
lee
lee's Avatar
Didn't realize it was a 1000R or that it couldn't be meggered with unless one had the tool. Told you I wasn't the TPS guy. There's something to be said for the older stuff after all.
lee is offline
post #9 of 14 (permalink) Old 11-27-2009, 05:23 PM
mikef4uk's Avatar
Lee, you could always get an old Triumph with those carburettor things and points and dizzy's and stuff!! at least it was always fixable
mikef4uk is offline
post #10 of 14 (permalink) Old 11-27-2009, 07:09 PM
lee
lee's Avatar
Actually I'd prefer a DBD34 Goldie. NOT the one in Mike's shed thank you very much.
lee is offline
