Leaking coolant - 1000 Senna - MVAgusta.net
post #1 of 7 (permalink) Old 11-15-2009, 11:22 PM Thread Starter
Send a message via Skype™ to AinsleyHenderson
Spent all of last week stripping down and cleaning my Senna. Put it back together and took it out on my favorite twisty road. About an hour after starting out I notice a fine spray of coolant on the inside of the faring scree high up about 2 inches from the edge closest to the rider. There was no sign of it coming from the tank near the stering head, and the temperature did not vary, and actually went down as long as I did not go under 35mph (60 kph).
When I got home, I stripped the faring of, and found coolant all over the left side around the main inlet hose, and the running down over the left side of the engine and the inside of fairing. The fine spray of coolant continued but only a couple more time, almost in tandem with hitting any serious bumps on the road.
I could not see any splits in the radiatior or associated hoses. Any suggestions on what is causing the leak would be appreciated.
Ainsley
AinsleyHenderson is offline
post #2 of 7 (permalink) Old 11-16-2009, 12:15 AM
leak
click clamp isn't tight enough..... replace it with a screw type clamp or even a Corbin clamp
post #3 of 7 (permalink) Old 11-16-2009, 01:00 AM
rents's Avatar
You could idle the bike in your garage with the fairing off. Let it get up to temp and see where the coolant sprays out.
rents is offline
post #4 of 7 (permalink) Old 11-16-2009, 01:09 AM
Ainsley, there is a weak spot on the top of the radiator and only leaks when on the gas. easy fix is to get the top part of the radiator isolated, mine cost me $70.00
Or do a search there is shit loads on the forum on leaky radiators.
adamv1000 is offline
post #5 of 7 (permalink) Old 11-16-2009, 02:36 AM
Ainsley,
As the Senna is mechanically idendical to the F4 1000R, I suspect you have a broken radiator (they break at the top next to the left side mount). Mine broke and I never successfully welded it - it just kept propogating, so I ended up buying on of the modified MV units nd have had no problems since.
Hopefully it's just a lose hose.
The easiest way to find a leak is with a radiator pressure tester.
Andrew...
PS I saw you yesterday, that was me on the Ducati that gave you the thumbs-up as we entered the Pacific Highway heading back towards Sydney (I still have the MV and the wife also still has hers - but she is away at the moment). O'h and yeah, boy those Bodis pipes of yours sure are loud.
andrew is offline
post #6 of 7 (permalink) Old 11-17-2009, 04:14 AM Thread Starter
Originally Posted by andrew View Post
Ainsley,
Andrew...
Andrew,
Many thanks for the advice. I think I will take the bike to Motorcycle Weaponary aand have them do it. I recall you and the Duc in particular - magnificant. I was nursing the bike home on Sunday when you went past. I had been blasting up the Old Road, and on to Kulnara when it starting hosing the inside of the faring screen.
The Bodis pipes are very loud, but when the bike is at full noise, it just sounds awesome. The tuning work done by Motorcycle Weaponary has really brought out the best in the bike.
Safe riding and would like to catch up.
Ainsley
post #7 of 7 (permalink) Old 11-17-2009, 12:58 PM
I had those I had the same issue...in fact mine would be even worse...when the temps would go up with the stock coolant it would hit like 220s in 100 degree weather and the temp would drop back down to say 180s because of proper riding...and then say we would stop and pull over to take a breather...I would see the coolant leaking out of the bottom fairing...and form a little puddle at the bottom. It all was very unnerving but it went away after I swapped it all out with water wetter. There was a leak somewhere but I guess draining the system and cleaning it out with vinegar solution and then putting water wetter coolant in it sorted it all out. The machine runs like a champ now. I could not be happier with my Senna.
suryad is offline
